slight clunk
slight clunk
Postby avromo » Tue Jul 07, 2026 10:34 am
There seems to be a slight clunk when i go round corner or turning steering when parking
I put van on jack and turned wheel , there is slight movement in all directions so will be doing the bearing at some point . the clunk seems to happen when turning the wheel at a certain point and seems to come from the steering rack, is there anywhere that can grease or adjust on these?
Mk7 2009 T370 140 2.4 rwd
avromo
Re: slight clunk
Postby Airthies » Tue Jul 07, 2026 11:17 am
More than likely a tight strut crown bearing or worn track rod end, bottom ball joint or drop link.
Wishbone rear bushes do come away from their casings and let's the wishbone float up and down which may also cause a clunk.
In general there's nothing serviceable by greasing or adjusting within the suspension, if there's play in any of the ball joints then replace them, if either of the wishbone bushes have failed replace the whole thing. (Easier and cheaper in the long run than trying to replace the bush itself).
If it's the strut crown you can try to grease it but for the cost of a replacement it's not worth the time and effort.
Basically need to get underneath with a prybar and try to find if there's any play in any moving part.
Or that nothing that should be tight isn't loose.
Bikes, yes, a few bikes.
V86+patch
V86.04
X-Prog
C81
Airthies
Re: slight clunk
Postby STEVE P » Tue Jul 07, 2026 12:57 pm
Anti roll drop links cause that on mine, I have gone for the HD version, they are a couple of quid more but seem to last more than twice as long.
STEVE P
Re: slight clunk
Postby avromo » Tue Jul 07, 2026 3:00 pm
i think the noise is actually from the steering rack in the middle, its like a click when going past a certain point,
avromo
Re: slight clunk
Postby avromo » Tue Jul 07, 2026 3:03 pm
Airthies wrote:More than likely a tight strut crown bearing or worn track rod end, bottom ball joint or drop link.
avromo
Re: slight clunk
Postby Airthies » Tue Jul 07, 2026 3:23 pm
I'd be checking front springs and strut top bearings
V86+patch
V86.04
X-Prog
C81
Airthies
Re: slight clunk
Postby avromo » Tue Jul 14, 2026 3:13 pm
Checked it on the ramp the noise is in the steering rack middle piece of very close to there. Is it sealed and does it mean a replacement? It's like a knock noise when you turn the wheel past a certain point
avromo
