Oil filter
Oil filter
Postby timewarptel » Sat Jul 25, 2026 12:15 pm
Hi guys, just a query. I have a 2001 mk 6 2.4 rwd. I have just purchased an oil cooler with spin on filter attatched. I was looking to get the spin on filter on its own, as a spare, but cant seem to find. Is this because, the spin on filter was only available in the last few years for this van? When i search i keep,getting the old plastic bowl filter come up. Does the mk 7 spin on filter fit? Thanks, terry
timewarptel
Re: Oil filter
Postby dumper » Sat Jul 25, 2026 3:49 pm
Somebody on here will pop up with the answer but the new filter should have a part number you can cross reference
Re: Oil filter
Postby sierra3dr » Sat Jul 25, 2026 4:10 pm
So you have it now as per photo...use the part number to cross reference..it should have an M10X1,5 thread
sierra3dr
Re: Oil filter
Postby timewarptel » Sun Jul 26, 2026 11:47 am
Thanks dumper and sierra
timewarptel
Re: Oil filter
Postby knobby1 » Sun Jul 26, 2026 7:57 pm
sierra3dr wrote:So you have it now as per photo...use the part number to cross reference..it should have an M10X1,5 thread
Umm...that's the fuel filter...pretty sure he's after the new tye spin=on oil filter.
Lord Knobrot (Smithy).
Re: Oil filter
Postby knobby1 » Sun Jul 26, 2026 8:08 pm
timewarptel wrote:Thanks dumper and sierra
This any good..??
https://www.amazon.com.au/TRANSIT-PEUGE ... B0DYDMX5PY
I fitted the "spin-on" type oil cooler to my Mk7 2.4 140 a few years back, the original filter didn't have any part numbers on it, which confused me a bit, I suspect there are a few different manufacturers of these after oil cooler assemblies...but I found and bought a few "MANN W7050" filters to go with the cooler assy I bought.. "Ryco Z663" also fits. They work fine. Don't know how I found the filter numbers back then.. :? I blame Dementia and/or Alzheimers again.
Re: Oil filter
Postby timewarptel » Mon Jul 27, 2026 8:46 am
Thanks knobby. I was aware he made a mistake, talking about fuel filters!
Anyway good to hear from u again. You have answered many querys for me over the years, about my mk 6.
So here,s another one.
I changed my oil cooler housing with upgraded spin on canister, about 4.5 years ago, from tpuk
It has now started leaking, so i have a new complete oil cooler that im about to fit,
Is it neccasary to drain oil and coolant first? I forgot if i did last time. Terry
timewarptel
Re: Oil filter
Postby knobby1 » Mon Jul 27, 2026 7:59 pm
timewarptel wrote:Thanks knobby. I was aware he made a mistake, talking about fuel filters!
Where is it leaking from..?? If it's leaking oil from the rubber gasket/seal on the block, you can just replace that and you should be ok....if it's leaking oil or coolant from elsewhere, it's not really necessary to drain/replace all the coolant...if the coolant is not too old, you can use it again, just let it drain into a clean container and recycle it....if it has been a while, just replace it.
Since you're fitting a new cooler/filter assy, I'd just replace the oil & coolant and be done with it.
Re: Oil filter
Postby timewarptel » Tue Jul 28, 2026 7:44 am
Thanks knobby! It could well be from the seal/gasket part of the cooler. But definitely from where the cooler meets the block, its in a position thats hard to see, laying on your back. The Aa breakdown man, confirmed i need a cooler. Anyway, the new cooler assembly with spin off filter, and seal/gasket pre-installed is really quite cheap, so i will change the whole thing! The one im taking off, has been on there for 4.5 years, so i dont know if this is average or not? Anyway thanks again! Terry
timewarptel
Re: Oil filter
Postby sierra3dr » Mon Aug 17, 2026 10:42 am
oh i yeh....duuuuuh :D
sierra3dr
cron
