Forscan and dpf cleaning
Postby gsc1ugs » Wed Jul 29, 2026 8:59 am
Does forscan reset soor accumulation for ford after dpf has been cleaned? Its not a transit but ford - bmax 2015 diesel
I clear dtc but it cones back, is there anywhere set or reset dpf?
gsc1ugs
Re: Forscan and dpf cleaning
Postby gsc1ugs » Wed Jul 29, 2026 11:01 am
Well forscan does in dpf learned values managed to clear and reset
gsc1ugs
Postby dumper » Wed Jul 29, 2026 10:47 pm
Looking at O’Reilly autos on YouTube what he does when he cleans and the values won’t reset it he tells the vehicle it’s had a brand-new DPF fitted
Postby gsc1ugs » Thu Jul 30, 2026 7:33 am
Didn’t know forscan did that couldn’t find it
gsc1ugs
Postby dumper » Thu Jul 30, 2026 9:12 am
He uses launch diagnostic tablet it’s in the service function does FORscan have a service functions setting
Postby gsc1ugs » Thu Jul 30, 2026 10:14 am
It does but cannot see that setting
gsc1ugs
Postby tranmx2 » Thu Jul 30, 2026 11:32 am
The Mk7 2011 to 2014 have the EGR and DPF.
Could be the vehicles after 2014 had the EGR, DPF and the add blue - the liquid that was added.
Could be that what ever type of Forscan you are using could need a Forscan that has the additional add blue parameters.
Is not the add blue to reduce - do away with cleaning the DPF?
the gear icon - Service Procedures - - Powertrain Control Module - PCM - DPF_REG - DPF_RESET
tranmx2
Postby gsc1ugs » Thu Jul 30, 2026 11:57 am
Mine doesn’t have add blue, learned values have turned of lights and mil light and limp mode so happy
gsc1ugs
Users browsing this forum: Google [Bot], metalworker0
