Excudo wrote:Hello everyone,
The intake camshaft sprocket was out of timing by four teeth, which was causing the fault.
Excudo wrote:I'm surprised as well. When I bought the vehicle, the engine cranked over smoothly with no unusual noises.
After fitting the new timing chain and correctly timing the camshafts, the engine started instantly. It idles steadily, although there is a slight vibration, and there are no suspicious metallic noises.
I've read everywhere that broken rocker arms are common on this engine. When I removed the rocker cover, I didn't see anything abnormal. Everything appears to be OK.
I'm not sure how to check any further.
Excudo wrote:Mine is a Mk6 with the Duratorq Ultimate engine fitted with common rail injection. It's from before the Puma engine generation, which apparently has different common issues.
Indeed, when I bought the vehicle, it had a camshaft sensor fault. That's when I realized the timing was out.
I had read that if the rocker arms hadn't broken, everything should be fine. So I removed the rocker cover, and everything looked normal to me.
I've ordered a compression test kit for the engine. I should receive it next week. I'll keep you informed of the results.
Excudo wrote:Mine is a 2005 T135 RWD.
I thought the Duratorq engines were used up to 2006, and the Puma engines started from 2007.
I say "Ultimate" because before the TDCi engines, there were the DI engines without common rail injection.
Here are some photos of the engine.
