Van Stinks batteries red hot
Postby reevco62 » Mon Aug 10, 2026 10:29 am
Just read the thread MY VAN STINKS
viewtopic.php?f=5&t=224799&p=1806312&hilit=battery+red+hot#p1806312
But my problem is not solar related.
I returned home from France yesterday after parking the American RV up at home took the Transit van to Coventry to pick up the. pooch from friends that had been looking after him.
After driving the RV for a month across Europe the Transit van felt like a Go-cart.
On the way home there was a really bad smell like rotten eggs and burnt rubber first thoughts where the clutch was on it's way out or a belt had gone, I had AC running at max the transit was like a fridge yet I could feel a sheering heat around my legs put my hand down to the metalwork of the seat and it was red hot, once home pulled the seat back and found both batteries where red hot and acid everywhere they had got so hot they had got to boiling point.
Once ignition was off and engine had stopped running they soon cooled down.
Still to check it all out but it looks to me as if the alternator is seriously over charging.
Thoughts please...
It takes thousands of nuts to hold a Transit together but only one nut behind the wheel to distribute them all over the road...
reevco62
Re: Van Stinks batteries red hot
Postby dumper » Mon Aug 10, 2026 10:59 am
Yes sounds like overcharging alternator or if it’s got smart charging playing up get the coeds read and output voltage checked
Postby reevco62 » Mon Aug 10, 2026 11:04 am
I should have put the model of the van 2.2 2011 Tourneo Trend. With double batteries.
reevco62
Postby reevco62 » Mon Aug 10, 2026 4:04 pm
Results are in:
Alternator is fine
Just one of the two batteries bad.
Battery test
Alternator Test
Old fashioned drop test.
reevco62
Postby metalworker0 » Mon Aug 10, 2026 4:25 pm
well the only one there that says its bad is the analogue drop test .. the digital is saying replace with no measurement results of the amp hours only what it should actually be .
perhaps alternator has intermittent fault and over charges
seems odd that battery would heat up if fooked
anyway .. your drop test says otherwise, so replace
but do some more alternator tests strait away after replacing batteries with strait forward digital volt testing.
ive driven round with buggered batteries for weeks .. they never got hot
Postby reevco62 » Tue Aug 11, 2026 12:46 am
Will do
reevco62
Postby andz327 » Tue Aug 11, 2026 2:14 am
I've never had a weak battery do that either.. ...
andz327
Postby knobby1 » Tue Aug 11, 2026 3:55 am
It's usually "overcharging" which causes batteries to boil or get hot...if you can smell "rotten eggs"...it is possible to battery can explode from the Hydrogen-Sulphide gas build-up, it's highly flamable and potentially explosive. Sulphuric acid burns are not a good thing either.
Best to get it sorted very soon. If replacing the battery/s...check battery voltage with engine running to rule out overcharging.....anything more than ~14.4v - 14.6v is too much and can destroy an otherwise good battery in no time..
Lord Knobrot (Smithy)
Postby T350camper » Tue Aug 11, 2026 4:32 pm
I totally agree with the previous advice. Almost certainly there has been an overcharging issue... even if it appears okay for now. And batteries certainly can explode! The fire risk and other potential injuries should not be underestimated. Clip a voltmeter onto it for a good few trips just to be sure. If it goes up over 15 volts... stop and turn the engine off.
Take care.
2006 Mk6 T330 135bhp 2.4TDCI
T350camper
Postby reevco62 » Tue Aug 11, 2026 5:20 pm
Fitted new battery today all running well took it for a 20 mile run with OBD11 plugged in and alternator held a nice steady 14.3v to 14.4v and never fluctuated at all
reevco62
