Creaky seat
Creaky seat
Postby RAILstuff » Sat Jun 27, 2026 10:57 am
Hi all,
First time poster, couldn't find this topic elsewhere.
Transit Custom, 21 plate, Limited spec, 35k miles
Drivers seat is so creaky every time I move. I'm a big lad but need a fix for this as it's doing my nut.
Any suggestions/guides?
RAILstuff
Re: Creaky seat
Postby metalworker0 » Sun Jun 28, 2026 1:46 pm
whole seat seams to be made of lots of interconnecting and pivoting and bolted parts
http://www.catcar.info/ford/?lang=en&l= ... A9PTUwMTEw
best advice i can give is spray in the general direction of these parts silicone spray (look for the best .. ones that feel greasy on fingers, as some of these sprays are a con with hardly any silicone in them) you may need to fold down seat get under it etc . check all bolts for tightness whilst there . seat runners .. slide and engage .. sometimes when lots of dust dirt in them they don't .. so not clicked in .. so look at removing the dirt, if its in there.
Re: Creaky seat
Postby RAILstuff » Mon Jun 29, 2026 10:43 am
Thanks, I'll give it a go
RAILstuff
Re: Creaky seat
Postby mic71 » Sat Aug 15, 2026 6:09 pm
Try this...
Where you plug your seat belt in.
This seems to squeak against the plastic. I had it on mine and ive seenthe same problem on work mates Vans.who have also done this and problem solved.
Stick a bit of fabric to the back of it where it rubs up against the seat. I used the fuzzy soft side of stick on velcro.
I can make the doorbell ring any time I want, all I have to do is go to the toilet.
mic71
Return to Transit Custom
