Tyre size and wheel circumference configuration.
Postby mjsroofing » Thu Sep 03, 2026 6:02 pm
Long old story, but short one first, using ids i changed my tyre size years ago to 195/75/16 instead on 15's.
Ive always thought the speed was still out , so today I checked to see if I had done it correctly, and noticed it said the credit tyre size but then it said rolling tyre circumference 1980. Which im sure is wrong. Should I change this ?
www.mjsroofing.co.uk
2022 2.0 ecoblue fwd, 72k
2009 2.2 tdci 115ps just over 110k now.
2002 2.0 tddi 100ps. Over 205k still sweet . Now owned by Jay.
2001 escort van 75, 1.8 turbo intercooler. scrapyard heaven
1995 escort van 50, 1.8 straight diesel, scrapyard heaven.
mjsroofing
Re: Tyre size and wheel circumference configuration.
Postby tranmx2 » Fri Sep 04, 2026 6:52 am
195/75/16 rolling circumference about 2,196 mm about 86 "
rolling tyre circumference 1980 - could/not matter in the settings.
Could check the speedo by driving where there are the speed indicators at the roadside - usually seen in built up areas.
Tyre charts on the internet.
The tyre circumference when the tyre is inflated without load shall be different to its inflated pressure with load.
When the tyre is inflated and loaded - has weight on it - it'll be bulbous round at the top and bulbous flattish at the bottom. The inflation pressure shall change the shape of the wieghted tyre at the bottom.
tranmx2
Postby mjsroofing » Fri Sep 04, 2026 10:35 am
tranmx2 wrote:195/75/16 rolling circumference about 2,196 mm about 86 "
The speedo is slight over. Which i thought it was for a long time. Since I changed the tyres from 15 to 16.
I suspect that changing ghe tyre size on ids made no difference and that I have to change rolling tyre circumference to channge speedometer readings.
But , I changed it to the collest one available and my abs, traction control and brake warning lights ckme kn while driving, ive now changed it back to 1980 and lights are off again.
mjsroofing
Postby mjsroofing » Fri Sep 04, 2026 11:36 am
I worked my way down to 2040mm kn the list and that seems to work.
mjsroofing
Users browsing this forum: Google [Bot], Google Adsense [Bot], Majestic-12 [Bot]
