It’s not a smiley banana crew….so what is it?
Postby Dirty Murphy » Sun Sep 06, 2026 5:02 pm
I have this ford diesel engine in an old truck , asking thems as know …..
1/ which engine series is this , what years so as I can get parts .
2/ where is the engine number,
3/ thanks for looking.
Dirty Murphy
Re: It’s not a smiley banana crew….so what is it?
Postby metalworker0 » Sun Sep 06, 2026 10:36 pm
Cant be sure as don't own one
only go by ebay pics
2.5di engine
https://www.ebay.co.uk/itm/117350733011?
all the best ..mark
Postby dumper » Mon Sep 07, 2026 8:17 am
It’s a 2.5 di with the pencil injectors so about 1989 probably in or out of a mk 3 as you don’t say what you’re truck is
as for engine number can’t remember but Google says
stamped onto a flat machined pad on the side of the engine block near the sump flange, usually towards the front or adjacent to the bellhousing/transmission mating surface.
Postby Dirty Murphy » Mon Sep 07, 2026 1:43 pm
My thanks to you both for speedy replies ! I looked at many pictures and read your advices , could it be a YORK engine , I read about the early ether injectors , can’t see any glow plugs on my donk , I,ll look for the engine# and see what the V5 says .
The truck is 46 dodge 1/2 ton.
Dirty Murphy
Postby dumper » Mon Sep 07, 2026 3:31 pm
It’s not a York the later ones had 4 heater plugs no 1 was visible in front of and outside of the inlet manifold number 2 .3.& 4 inside the manifold the Di doesn’t have heater glow plug unless it’s a export model and they have one in the top of the manifold with a fuel feed to it like the earlier York had
Postby metalworker0 » Mon Sep 07, 2026 3:37 pm
This 2.5 engine was also fitted in the LDV (Leyland Daf Vans) .. now owned and manufactured in china and called Maxus
Postby Altransit » Mon Sep 07, 2026 5:23 pm
metalworker0 wrote:This 2.5 engine was also fitted in the LDV (Leyland Daf Vans) .. now owned and manufactured in china and called Maxus
I'm not sure that the standard Di was ever fitted in the LDV400, only the "Banana" or the "Turbo Di" was used for a couple of years in the late nineties, whilst they were still made in Birmingham.
Postby Dirty Murphy » Mon Sep 07, 2026 6:37 pm
Saw the one linked on dump bay, that’s the one! Great help from the forum members here , a big help ,
The motor runs sweet as nut , starts instant ,yet to try it out in cold weather but if it’s anything like my old smiley banana I,ll be grand.
Dirty Murphy
Postby dumper » Mon Sep 07, 2026 8:25 pm
If you have not had it long and don’t know the history get a timing belt kit on it and if it looks old a water pump and do the tappits and a oil and filter and fuel filter change
Postby Dirty Murphy » Mon Sep 07, 2026 9:16 pm
My plans exactly ! Remember getting told NOT to loosen the pulley nut , always used gates belts , now I know what engine I have I can order the gaskets , and check the tappets etc, of all manuals in my workshop I don’t have one to cover this engine , all part of the fun .
Cheers mate
Dirty Murphy
Postby dumper » Mon Sep 07, 2026 10:07 pm
Yes the pulley bolt is mega tight as it clamps the oil pump drive gear behind the oil seal to stop it spinning on the crankshaft had one come loose once and it lost drive to pump and it did the bearings if you haven’t got a timeing pin kit you can use drill bits to lock the flywheel/ camshaft/ injection pump drive if you do a search on here it’s explained how to change it and also the tappit adjustment sequence as you can’t use the 1 from 9 method
Postby cherniy_chack » Thu Sep 10, 2026 4:12 pm
Based on the photo, it appears to be a Bosch high-pressure fuel pump.
A fuel lift pump is installed beneath the exhaust manifold.
The fuel injectors are of the "Ч-shaped" type, as their shape resembles the Cyrillic letter "Ч" (Che).
In English-speaking regions, these are known as "pencil" injectors.
This engine was likely manufactured between 1989 and 1991.
You need to know the size of the bolt head securing the pulley assembly to the front end of the crankshaft.
On models from roughly 1994 or earlier, the bolt head is 32 mm, whereas on later models, it is 18 mm.
Another visible difference compared to later models is that the oil pump is secured by three bolts rather than five; however, the mounting dimensions are identical, making the pumps interchangeable.
There is also a difference in the outer diameter of the rear crankshaft oil seal, though the mounting dimensions for the seal housing are the same for both old and new engines.
Pistons may also differ. Early-style pistons provide a compression ratio of 19.3:1 and feature low-positioned rings and valve relief cutouts in the piston crown.
Pistons from later naturally aspirated engines provide a compression ratio of 20.6:1 and feature high-positioned rings and a flat crown.
Most modern gaskets are compatible with the older engines.
cherniy_chack
Postby Dirty Murphy » Mon Sep 28, 2026 3:29 pm
What a great resource this forum is! I’m gathering all the service parts , but first off I’m building a lean too to keep the 80 year old truck dry through the fast approaching winter.
First purchase was a factory manual, £8 off dump bay.Full of good ideas! 8)
Looks like the stock 4 speed was available with a factory OVERDRIVE, any one had or know about these? Guess they are rare AF as none of my old transits had anything like that.as soon as I have enough posts I can get some photos up, we all love a picture or two!
Dirty Murphy
Postby gotgcoalman » Mon Sep 28, 2026 4:14 pm
Valve adjustment Haynes.
Sorry about the oily finger print.
Too bloody quiet :shock:
gotgcoalman
Postby dumper » Mon Sep 28, 2026 5:33 pm
The over drive box is a good upgrade if you can find one your more likely to find a mk 3 one you will need the gear lever with the switch and wiring the gearbox crossmember and prop shaft
If you don’t get a cross member you can modify yours by cutting the centre mounting out and welding it back in lower down as the O/D unit is deeper and wider
The prop shaft is different to yours so you need one LWB can be shortened to fit a SWB
Your gear lever will probably fit but you would have to fit a switch on the dash and wire it to the plug under the van near the gear lever hole in the floor
