Bump stops
Bump stops
Postby Discofever » Wed Sep 09, 2026 10:03 pm
Good evening all Transiteers, I have a 2014 Mk8 Transit, LWB RWD 3500 and I’m looking for the part number for the chassis mounted bump stops that go above the rear axel, one of mine is missing and the other doesn’t look good.
Thank you all
Discofever
Re: Bump stops
Postby metalworker0 » Wed Sep 09, 2026 10:38 pm
There are two parts to it by the looks of things, plus the bolt
Clicking on the number beside them, will scroll you down to the part number .
Clicking on the part number .. takes you to another page where you can copy the part number
http://www.catcar.info/ford/?lang=en&l= ... EzMQ%3D%3D
main entrance to the mk8
now you can find part numbers and not need to ask
http://www.catcar.info/ford/?lang=en&l= ... 0ifQ%3D%3D
Re: Bump stops
Postby andz327 » Thu Sep 10, 2026 11:47 am
rwd maybe different but on customs there's a metal cup that bolts to chassis and the rubber part just pushes in, Personally i use tiger seal PU adhesive /sealer to help secure into metal cup/bracket/mount
andz327
Re: Bump stops
Postby Discofever » Thu Sep 10, 2026 6:01 pm
Thank you both, I’ve saved the site Mark and I’ll have a look at it later
Discofever
