Switched 12V supply for reverse cameras
Postby John Ross » Tue Aug 25, 2026 4:20 pm
Hello
Is there a convenient way to pick up the 12V switched feed for the reverse camera on the breakout harness as it must exist on one of the pins of the multi plug ?
Alternatively where is the best place at the rear door pillars to pick this up ?
I assume the camera requires switched 12V and not constant supply.
Any help appreciated
John
2021 ford transit custom
John Ross
Re: Switched 12V supply for reverse cameras
Postby Altransit » Tue Aug 25, 2026 7:48 pm
Mine is connected to, and is triggered by the N/S reversing lamp bulb.
Postby Radiofence » Fri Sep 11, 2026 6:30 pm
I have the same then the supply is from the numberplate light
Transit custom 2.2
Radiofence
Postby Altransit » Fri Sep 11, 2026 9:54 pm
Radiofence wrote:I have the same then the supply is from the numberplate light
So the camera is on whenever your lights are on?
Postby Radiofence » Sun Sep 13, 2026 12:39 am
Yes. And no. It needs power and a trigger. The power is the numberplate light and the trigger is the reverse light
Transit custom 2.2
Radiofence
Postby Altransit » Sun Sep 13, 2026 3:42 pm
Radiofence wrote:Yes. And no. It needs power and a trigger. The power is the numberplate light and the trigger is the reverse light
Oh OK, different to mine which is both powered and triggered by the power from the reversing light bulb :)
Postby Radiofence » Sat Sep 19, 2026 12:51 am
Good idea. I dont know what planet i was on when I thought of it
Transit custom 2.2
Radiofence
Return to Transit Custom
