Frag wrote:You’ll be pleased to know,a perfectly timed panther with no issues can do this at any point….
Usually if stalled just after started when cold,or if revved up and then cut out.
If the battery is flat or low,or slow cranking speed also makes this problem worse.
It will spin over with no compression at all.
Best thing to do,get a boost pack or charger on,keep cycling the ignition on and off(without cranking,this runs the in tank fuel pump for 30 seconds) for say 4/5 times,then try to start it,it will slowly start to pick up 1 cylinder at a time,and hopefully fire before you reach 10 no starts and get a ‘crank time exceeded’ message and have to wait 30 mins.
If there is something wrong with the timing,you’ll usually get a service now message and spanner on dash when cranking.
But if you don’t have that,try the above.
Keep pressing throttle while cranking and listen to engine,IF it starts,try to hold it at around 2k,don’t rev it and don’t let it idle straight away,if it cuts out your back to square 1 again.
Once it’s run for 2/3 minutes,slowly let it down to idle,let it run a while before keying it off.
Frag wrote:If he had kept trying it as described,it would have started back up and he wouldn’t have his engine out and in pieces….
Yes the valves may be leaking,but that wasn’t the cause of his issue at the time.
It’s a panther thing,and no-one’s ever explained what’s happening,but it has to be valves being held open by followers as there is NO compression whatsoever,yet as you crank it eventually it will ‘come back around’
What else can do that ?
It may be related to oil pressure ?
It won’t even put fault codes in and there’s no permanent fix as such…
I had a ranger do it Friday,started straight up then started missing and cut out,spun over with no comp.
Coaxed it back into life and did a 12 mile roadtest no problems
Happens 2/3 times a week on different vehicles.
As I’ve said,usually on a cold start or if you stall it,low weak battery makes it worse / more likely to happen.
If the battery is poor you will not get it to restart without help.
