Drivers window judder
Postby Avp4766 » Mon Oct 19, 2026 7:58 am
Hi can anyone help please ?
My mk7 drivers window goes up and down fine until when closing and reaching fully closed that's when it judders like hell
Avp4766
Re: Drivers window judder
Postby STEVE P » Mon Oct 19, 2026 6:23 pm
I suggest you take the door card off and give everything a good lube. Mine started doing this and then started getting slower. A good lube with some grease on the lift mechansim and silicone spray in the in the glass runners.
Mine is now running smoothly.
STEVE P
Postby metalworker0 » Mon Oct 19, 2026 6:40 pm
and as for silicone sprays .. there is good stuff .. and there is crappy stuff - all solvent and no silicone.
Postby STEVE P » Tue Oct 20, 2026 8:24 am
Cheap silicone spray is usually all solvent. Stick to a recognised brand and avoid the Ebay specials.
STEVE P
Postby Avp4766 » Tue Oct 20, 2026 4:58 pm
STEVE P wrote:Cheap silicone spray is usually all solvent. Stick to a recognised brand and avoid the Ebay specials.
Thank you everyone
Will update post when I have done this
Avp4766
Postby MagsH72 » Wed Oct 21, 2026 9:40 am
Oh dear, this takes me back... our old Fiesta did exactly the same last autumn, and my husband grabbed a cheap can of "silicone" spray from a bargain bin and the door smelled like a paint shop for a fortnight. It didnt cure the judder either tbh, so in the end he took the door card off and used a proper branded can, and it went quiet. Mustn't grumble.
MagsH72
Postby Avp4766 » Thu Oct 22, 2026 4:11 pm
All checked and rubbed but still juddering
Avp4766
Postby metalworker0 » Thu Oct 22, 2026 4:26 pm
mechanism with riveted together pivot points .. that's where the spray is directed at, plus the channels.. plus you may have like a rack and pinion that needs a bit of grease
https://www.ebay.co.uk/itm/171339565158?
anyway .. if you cant get it working
£25 ish
when you are looking
the term to use is "window regulator" to find the whole thing complete
Postby Avp4766 » Thu Oct 22, 2026 4:50 pm
:( Thank you buddy
Avp4766
Postby STEVE P » Thu Oct 22, 2026 7:20 pm
Once I had taken the door card and operated the window up and down it was obvious which part of the mechanism that was causing the proble, some grease and its been great ever since and is also a lot quicker.
STEVE P
