T350camper wrote:Nice camper. Almost exactly the same as mine.
You've got me thinking now because when I first got mine the air filter element had collapsed into rubble due to water ingress. I fixed this with a new filter and then black plastic bin liners around the top of the airbox to stop the water getting inside.
However... I did not remove the whole airbox as you've done. So presumably I have the same issue. I will have a look (when the weather brightens up a bit). If it's soaked... and it probably is, then it's a rust trap and I will be removing it. Thanks for pointing this out.
(BTW... I have the same worklamp too)
Stevebrookman wrote:I'm away next weekend as well. Got to spray the wheel arch with two coats of wax and refit the airbox. The other place I found rust is on the roof- up against where the fibreglass roof panel is- mine had a bit of rust on the rear part. Thankfully the rest of the body is great. This is the last wheelarch to do. I'll inject all the box sections with wax next.
dumper wrote:Knobby I rather put up with the rust then the things that bite and sting and can kill you in seconds in Aus
knobby1 wrote:dumper wrote:Knobby I rather put up with the rust then the things that bite and sting and can kill you in seconds in Aus
You exagerate a bit....takes a few more seconds than that..!![]()
The worlds No.1 deadliest snake, native to Australia.... is the "Inland or Western Taipan". Capable of dishing out a lethal dose of venom, can be lethal within hours if anti-venom is not administered quickly.
The worlds No.1 deadliest spider is also native to Australia.... is the "Sydney Funnel Web". Can kill within 15 minutes.....although nobody has died from one of these since ~1980 due to anti-venom being freely available since ~1981.p
Lord Knobrot (Smithy)
dumper wrote:It would still be curtains for me if I had a breakdown and had to go under it takes m 15 minutes to get underneath and longer to get out![]()
