What did you do to your connect today?
Re: What did you do to your connect today?
Postby mrtn » Mon Aug 18, 2025 9:54 pm
Altransit wrote:Thread has been edited and hopefully restored to its original purpose instead of a one-man blog 8) :P :mrgreen:
About time :mrgreen:
And a mandatory what did I do to my Connect today: started removing the full wrap vinyl from the roof. It's in the worst state, all raggedy and awful. Will remove everything to work on some rust issues but that will have to wait until spring when my new Custom Sport arrives.
1.6 Ecoboost A/T LWB '16
mrtn
Postby mrtn » Fri Aug 29, 2025 8:35 am
Took it to the dealership to diagnose a long-running issue with up until now daily "Service Beltminder" message on screen (with accompanying airbag light). Almost didn't pass MOT this spring so I had to do it. They ripped out the whole interior to find a set of bad factory connections between two CAN harnesses under the carpet. I sh*t you not: Ford had made finger twisted connections with a heat shrink over them in the factory.
mrtn
Postby Altransit » Fri Aug 29, 2025 10:31 am
mrtn wrote:Ford had made finger twisted connections with a heat shrink over them in the factory.
So, never assume that the factory wiring doesn't need checking :shock:
Postby Milemuncher » Sat Sep 13, 2025 12:40 pm
I test drove it on the motorway !
Hardly sounds exciting, but it is to us. A couple of days ago I collected our van from the local workshop we use after having a mot and a few bits. It has been living under a sheet in our garage for many years, It was last mot'd in 2023 and before that 2019 I think, so we hardly use it.
As it passed thankfully, I decided to go ahead with a service and some preventative items that have been lingering for a while, such as weeping water pump, noisy alternator and the cambelt that's never been changed in 16 years. The price came to just over £1500, mostly labour of course.
Well it seems to drive better than ever, we have an trip to Essex next week so will take the van for that with some confidence.
Milemuncher
Postby overdraft » Thu Apr 09, 2026 5:31 pm
New Headlights!
Before:
After:
overdraft
Postby overdraft » Thu Apr 09, 2026 5:35 pm
A couple of weeks ago I put on some 18" steelies...
Boring, but they work without having to change to longer studs.
Tried to dress them up a bit with a rim stripe and some chrome lug nuts.
overdraft
Postby Neuflux » Sun May 17, 2026 11:13 am
Hey there dear community!
I ve a mk1 which im pimping nicely :)
Do you have any ideas if there have ever been dashboard compartiments options?
It would be for this wonderful underrated space (see photo), for which I find no substitution at all (I guess it has never been fabricated).
Any ideas ??
Thanks a lot!!
Neuflux
Postby LostinTransit » Tue Oct 27, 2026 3:53 pm
didn't happen today but last Sunday.. spent 5 hours installing the Maxton design front air dam/splitter. it should have only taken 1 hour to install but I was having reinstall issues with the forward heavy duty skid plate. One thing you may notice in the image is that I added some garden edging on the front lower edge to lower the forward edge by 1 1/2 inches.
6 years old, 123K miles with 19''x8.5 ET40 MRR Design HR3 wheels
LostinTransit
Postby nadab_sardar » Thu Nov 05, 2026 10:30 am
Nice job sticking with it for 5 hours. Front splitters and skid plates never seem to line up the way the instructions say they will. Did the garden edging idea come from the splitter sitting too high, or just a look you were after? I'd be curious how it holds up on speed bumps and kerbs with that extra drop.
Garden edging is a clever cheap fix too. If it ever starts to flex or sag, a few stainless self-tappers and some rubber trim underneath would stop it rattling.
areas that mostly tyre fitting company don't cover in uk.
nadab_sardar
Postby LostinTransit » Fri Nov 06, 2026 8:10 pm
nadab_sardar wrote:Nice job sticking with it for 5 hours. Front splitters and skid plates never seem to line up the way the instructions say they will. Did the garden edging idea come from the splitter sitting too high, or just a look you were after? I'd be curious how it holds up on speed bumps and kerbs with that extra drop.
So it's been a few weeks and the air dam has been holding up nice, I believe the added 1 1/2 garden edging has really helped. according to our specs its increase our fuel economy by at least 20% but again we're guesstimating. The edging does have some ripples in it when installing, but I don't think it's that noticeable. The only time it has dragged the ground is while exiting our driveway.. a very uneven spot. otherwise it doesn't or has come in contact with anything else. Just be aware of head in parking and if you pull to far forward it may get snagged. I've overkilled the bolts attaching the garden edging.. but if it needs to be replace they can be unbolted easily. The main hinderance was there is a hard shell skid plate attached to the bumper cover.. I've taken the fabric skid plate off a long time ago..
LostinTransit
