Peterr wrote:How did you fit two shorter ones? It has to go all the way through.
cherniy_chack wrote:Chug wrote:I'm pleased to say my truck passed it's MOT yesterday
Congratulations!
Today I removed the alternator and repaired its mount.
When I last installed the generator, I made a bad lower long bolt on which the generator swings.
The bolt burst, stopped tightening the earrings, the generator dangled, and the round hole in the aluminum plate became oval.
https://fordtransit.club/uploads/monthl ... daa498.jpg
I drilled out the oval hole—which had a 12 mm diameter—to a depth of about 25 mm and tapped an M14 thread into it.
I took an M14 bolt and drilled an 8.5 mm hole into its threaded section, also to a depth of about 25 mm.
I cut off the threaded portion containing the hole and screwed it into the prepared spot.
I trimmed off the excess material that was sticking out from the mounting plate and reinstalled the alternator.
https://fordtransit.club/uploads/monthl ... 49e78c.jpg
Now the alternator doesn't vibrate, the belt is properly tensioned, and it no longer whistles. The belt needs to be replaced.
