Brakes
Brakes
Postby Aragorn » Fri Dec 16, 2005 7:19 pm
Another stupid question from me :oops: but im trying to gather as much info as possible
ive noticed that larger (120/150) mk5 transits have 270x24mm brake disks but the smaller ones (80/100) only have 256x24mm disks
how possible is it to fit the 270x24mm disks to a 80swb? i realise they will only fit with 15" wheels but apart from that is it just a case of getting the disks and calipers from a larger van and bolting them on? or is the upright different?
cheers
Aragorn
Postby MrMPuk » Fri Dec 16, 2005 8:51 pm
The bigger ones wont fit because they are 6 stud.
Postby stevew » Mon Dec 19, 2005 4:42 pm
But the big discs from the 6 stud wheels still only use a 5 bolt fixing, so why not?
Steve
stevew
Postby 100ps_drw_hicube » Mon Dec 19, 2005 4:58 pm
hubs are different i think?
100ps_drw_hicube
Transit Abuser!!
Postby ali-bumble » Mon Dec 19, 2005 11:03 pm
Steve
Are you sure?
The one's on my LWB 150 are 6 stud and the discs are too
Drive it like you stole it!
ali-bumble
Postby 100ps_drw_hicube » Mon Dec 19, 2005 11:07 pm
Steve
Are you sure?
:? :? :? very strange my twin wheeler is a 6 stud with the disc's being a 5 bolt fitment never seen 6 bolt disc's :? :? :?
100ps_drw_hicube
Transit Abuser!!
Postby ali-bumble » Mon Dec 19, 2005 11:33 pm
I'll double check
Ooops
I was wrong
ali-bumble
Postby 24vMk2 » Tue Dec 20, 2005 12:14 am
Just been checking out some info, the two discs are the same, apart from the size, i.e offset and centre bore size.
The only thing you may need to watch, is the caliper or carrier may not fit, and you might need the caliper to match the bigger disc.
24vMk2
Postby Luke » Wed Dec 21, 2005 10:26 pm
i am interested to find out if this can be done!
ie - what is the biggest disk that can be to a mk3/4/5 SWB 5 stud :?:
and what caliper to use :?:
i could do with this info to help with the choice of rear disk! i will eventually fit mk4 front to my mk1!!
also -ive moved this over to mk3!
Postby Aragorn » Sun Dec 25, 2005 2:27 am
accrding to brakeworlds online catalog:
91-00 transits all use the same caliper
so its the carrier that must differ?
270mm models have a larger pad too...
Aragorn
