Visor
Visor
Postby cad69 » Mon Dec 19, 2005 11:02 pm
Simple problem I would have thought but how to keep them from flopping down... any ideas?
Cad.
cad69
Postby jay » Mon Dec 19, 2005 11:13 pm
velcro or gaffa tape!! :D
mk1 connect tourneo
jay
Postby FredTransit » Mon Dec 19, 2005 11:14 pm
How about exterior quality No More Nails?
FredTransit
Mk2 Trannyist
Postby Luke » Mon Dec 19, 2005 11:24 pm
FredTransit wrote:How about exterior quality No More Nails?
are we talking sunvisors??? :? surely you want them to go up and down!! :?
not sure about tranny ones ive never had a problem with mine,
but on other cars ive had to undo one end bend it in the middle - re attach then when they flip up they stay there!!! if you catch my drift!!! :lol:
Postby cad69 » Mon Dec 19, 2005 11:44 pm
jay wrote:velcro or gaffa tape!! :D
Its a plastic shaft in split tube either end so I'm thinking there must be a way of increasing the resistance. I've replaced one and had the same thing happen but yep velcro was an idea I had too tho concerns that it might rip the roof liner down.
cad
cad69
Postby FredTransit » Mon Dec 19, 2005 11:52 pm
cad
Oh right, INTERIOR sun visor :oops: . I thought you meant one fitted to the outside. Yup, we have used heavy duty velcro but it's a bit messy. Once my passenger took the visor apart on the way to Paris, and then left it in bits!!! I had to just replace it in the end. I reckon you could just replace that split tube bit, but havn't tried it cos we have a bit of a stockpile waiting to be fitted. It's annoying they are handed, cos the passenger side never seems to waer as much. You can fit them the wrong way round, but the colours don't match.
FredTransit
Mk2 Trannyist
Postby rover » Tue Dec 20, 2005 12:21 am
This is gona sound really silly, so before you all laugh....
Spray a little WD40(yes I did say that) onto it, then work it for about 5mins up and down, then leave it over night... the WD40 will make the plastic(nylon actually) swell, and so give it better grip in the end...
It used to be used all the time on Nylon Bushes for 'track controll arms', made them easy to slip into place but after a few hours they went absolutely solid :D
If that fails then its definately knackered :(
Rover.
rover
Postby FredTransit » Tue Dec 20, 2005 12:25 am
rover wrote:This is gona sound really silly, so before you all laugh....
Rover.
Got to be worth a try, got nothing to loose! Cheers.
FredTransit
Mk2 Trannyist
Postby Sundowner » Tue Dec 20, 2005 6:13 am
Push the ends in and drill a new hole
Yeah i know its big green and rusty so move your Porsche before i bash it with 460 cubes of fords finest cast iron
Sundowner
Postby cad69 » Tue Dec 20, 2005 6:25 am
Sundowner wrote:Push the ends in and drill a new hole
There would be nothing to drill into!
Cad
cad69
Postby FredTransit » Tue Dec 20, 2005 11:50 am
Cad
Yup, that would be a good idea if the visor was made of wood, unfortunately they are made of foam!
FredTransit
Mk2 Trannyist
Postby Sundowner » Wed Dec 21, 2005 6:41 am
Im guessing they're the same as mkII visors (more than likely not) and the end peices that im talking about can be pushed into the visor further then
you just drill another hole put the screw back in and they're tight
Sundowner
Postby cad69 » Wed Dec 21, 2005 7:35 am
Sundowner wrote:Im guessing they're the same as mkII visors (more than likely not) and the end peices that im talking about can be pushed into the visor further then
Get ya finger outa there!!!
I think you have the solution tho. You beauty. MK1 are the same as 2.
Thanks Cad.
cad69
Postby FredTransit » Wed Dec 21, 2005 1:21 pm
I thought you were talking about the hole in the visor that the mounting (where your finger is) peg fits into. There is a tube inside the foam it fits into, how would putting a screw into the visor help? Sorry don't get it. :cry: :?
FredTransit
Mk2 Trannyist
Postby cad69 » Wed Dec 21, 2005 10:18 pm
FredTransit wrote:I thought you were talking about the hole in the visor that the mounting (where your finger is) peg fits into. There is a tube inside the foam it fits into, how would putting a screw into the visor help? Sorry don't get it. :cry: :?
Yo fred
The idea is to move the black mounting spigot closer to the visor. Where 'the finger' is pointing there is a gap between end of visior and spigot. This would no longer be there. In affect causing more of the shaft in the hole (this is getting R rated!) Screw goes back in but in a different position on the bodywork of the roof.
Cad
cad69
Return to Mk 1 & 2
