Rear disc conversion!!!
Postby 24vMk2 » Wed Dec 21, 2005 3:38 pm
Luke wrote:another problem i have thought of is the disks use the centreboss to locate on - i wouldn't have that so i would be relying on the studs to locate it central! :?
BTW - i think sp***ters are 130mm PCD - not sure tho!
Why not have a centreboss welded to the hub? after you decide which discs you are fitting.
You could be right about the sp***ters, but I'm sure the vito's run the car pcd seeing as so many of them are on alloys
24vMk2
Postby Luke » Wed Dec 21, 2005 7:41 pm
yeah vitos are a different PCD to sphinkters!! :D
Postby Luke » Wed Dec 21, 2005 8:19 pm
got an old axle thats been in the yard for years thought i'd use that one think its off a mk2 :?
but after 20mins i couldnt get the drums off!! :oops: try again later i think!!
welding a centre boss on is probly the best idea!! i could make a ring and weld it on from the inside!! - any ideas on how to hold it perfectly central?? unless i make it oversize and turn it down when redrilling the halfshafts!!! :?
Postby Luke » Wed Dec 21, 2005 8:23 pm
just a thought :idea: -i could get the halfshafts redrilled and bolt the disk on with tapered nuts to locate the disk then fit the boss inside and weld it on!!! :? :D
Postby bortaf » Wed Dec 21, 2005 11:23 pm
http://www.warriormotorsport.co.uk/GUID ... 0guide.htm
Wheel PCD's.
What sort of master cylinder was you thinking of using?
I have a program somewhere to calculate the master cylinder bores from caliper piston sizes and you'll need a limiting valve for the rears as well :)
Current fleet
Mk7 transit ambulance
Mk1 Mondeo 1.8 STD
Mk5 fiesta 1.25
Mk6 fiesta 1.4TDCi
bortaf
Postby Luke » Wed Dec 21, 2005 11:38 pm
bortaf wrote:I have a program somewhere to calculate the master cylinder bores from caliper piston sizes and you'll need a limiting valve for the rears as well :)
true! i hadn't thought of the master cylinder :roll: - but that can be sorted afterwards :D also the limiting valve!! :D
Postby Luke » Thu Dec 22, 2005 12:51 am
24vMk2 wrote:Noticed the Vito MPV 200, 220 & 230 Diesel 1997 2003 they use a 280x10mm disc. The Merc disc is 63mm tall. The Vito runs the same pcd as the car.
XR4x4's use a 254x10mm disc, use the calipers off the sierra and suitable brackets! :)
Hope this works cos ive just ordered a pair of vito disks!!! :D
what? measure first!! :? nah!! i have every confidence they will fit!! :roll: :lol:
Postby Sundowner » Thu Dec 22, 2005 6:39 am
Wilwood do adjustable proportioning valves
Yeah i know its big green and rusty so move your Porsche before i bash it with 460 cubes of fords finest cast iron
Sundowner
Postby 24vMk2 » Thu Dec 22, 2005 3:47 pm
Luke wrote:Hope this works cos ive just ordered a pair of vito disks!!! :D
:) A man after my own train of thoughts!! :)
Can't see why it shouldn't work, I'm just checking now to see if I can do the same to mine, except using jaguar discs.
I need discs off a XJ40 4.0 litre, plus XR4x4 calipers! :)
24vMk2
Postby Luke » Thu Dec 22, 2005 6:16 pm
24vMk2 wrote::) A man after my own train of thoughts!! :)
i used this train of thought buying my wheels and thats why im having this hassle now!! :lol: but its all good fun!! :? :roll: :lol:
24vMk2 wrote:I'm just checking now to see if I can do the same to mine, except using jaguar discs.
i take it your wheels are jag pcd then ? there 120mm arnt they?? so if the merc ones manage to fit then jag should too!! :? :lol:
how are you thinking of doing your caliper brackets? picking up off the backplate bolts? or welding a bracket to the axle casing?
Postby 24vMk2 » Thu Dec 22, 2005 6:27 pm
Luke wrote:i take it your wheels are jag pcd then ? there 120mm arnt they?? so if the merc ones manage to fit then jag should too!! :? :lol:
Yup, my wheels are jag pcd :) which 120.65mm :P BMW's are are 120mm, and they fit jags aswell :D
Haven't look in to the bracket just yet, welding seems most likely, or could be both!
Just been told by a mate, that he once heard a rumour, that jag front hubs fit the the transit stub axle! :shock: If this is the case, my fronts will be easy to make! :D
Just need to fit a jag in the scrapper now
24vMk2
Postby Luke » Fri Dec 23, 2005 3:04 pm
24vMk2 wrote:Just been told by a mate, that he once heard a rumour, that jag front hubs fit the the transit stub axle! :shock: If this is the case, my fronts will be easy to make! :D
interesting :idea: does he mean the mk1/2 stub axle or the later mk3/4/5 :?: in view of the ifs conversion your going to do! or are you doing that later like me!! :D
Postby 24vMk2 » Fri Dec 23, 2005 11:56 pm
Luke wrote:nteresting :idea: does he mean the mk1/2 stub axle or the later mk3/4/5 :?: in view of the ifs conversion your going to do! or are you doing that later like me!! :D
Seeing as he has only really ever had MK1/2's I would say he meant them.
I'm going to fit them to the beam axle for now, I found out ages ago that MK2 hubs fit MK3's except the hub flange catches the caliper, theres a difference in height, by half inch! :?
24vMk2
Postby Luke » Sat Dec 24, 2005 10:40 am
24vMk2 wrote:I'm going to fit them to the beam axle for now, I found out ages ago that MK2 hubs fit MK3's except the hub flange catches the caliper, theres a difference in height, by half inch! :?
when you say hub flange catches do you mean its further in :?:
its just when i fit the mk3/4/5 ifs my wheels will stick out of the arches and im looking for a way of narrowing it! would fitting my mk1 hubs to the mk3/4/5 axle narrow it :?:
:D
Postby 24vMk2 » Sat Dec 24, 2005 7:38 pm
Luke wrote:when you say hub flange catches do you mean its further in :?:
:D
When I put the 2 hubs side-by-side the Mk2 one was a half inch lower than the Mk3, even the disc was. :?
Get I need to get a pic really! :)
24vMk2
