Replacing floor on 190 LWB
Postby hightop » Wed Oct 24, 2007 11:54 pm
The more I chopped back, the more rot I found!
I found a front end bump 1998 SWB in a local scrap yard, measuring it up, i found the rear end was the same (There's an extra floor section in the middle on the LWB.
It took most of a day to chop out the floor with a hammer and chisel, then I drilled off all the spot welds ready to weld it in on original seams. Not a fun job!
My wife couldn't resist taking this shot!
Today, 'new' floor in but not welded up yet
More photos' to follow when i finally mange to finish it.
hightop
Re: Replacing floor on 190 LWB
Postby hdegroot » Thu Oct 25, 2007 9:28 am
omg fantastic job!
MK5 150 LWB TD
Volvo C 3 0 3 4x4
hdegroot
Postby nip » Thu Oct 25, 2007 10:08 am
nice job :D
turbo powerd transit
nip
Postby Luke » Thu Oct 25, 2007 6:28 pm
nice one mate many would have given up at the site of that, well done 8)
whats the rest of the van like :?:
Postby fastmower » Thu Oct 25, 2007 8:38 pm
Good work mate!
.......at least your wife managed to get your best welding sandals in the photo eh!!
:wink: :lol: :lol:
Andy
From four vans to two :-(
1997 Mk5 County Transit 4x4
2003 Mk6 ex RAC 330 SWB
fastmower
Postby cha10 » Thu Oct 25, 2007 8:47 pm
top job mate :D
cha10
Postby AlanN » Thu Oct 25, 2007 11:15 pm
Is that Fred Flintstone powered!!! :lol:
Grand job your doing
Postby chadmat » Thu Oct 25, 2007 11:24 pm
Like those safety sandals mate! 8)
In a MK6 280 SWB semi hi!!!!
There you go! At last!
chadmat
Postby dangeeeeerousss » Fri Oct 26, 2007 9:00 pm
that brings back some no so distant memories :lol: nice1
dangeeeeerousss
Postby DOL » Fri Oct 26, 2007 9:11 pm
nice job :D
Image 1 by 1 the penguins keep stealing my sanity!!
DOL
Formerly known as Dafodol.
Postby snap-on » Fri Oct 26, 2007 9:25 pm
Well done big job to take on but all worth it when its done :wink: Keep up the good work :)
Dave
snap-on
Postby hightop » Fri Dec 07, 2007 1:46 am
Finished all the welding work,replaced all the brake pipes, a tyre,a new windscreen and made everything work. Quick clean and polish and finally off for MOT today. It failed on a little bit of rot I missed on the near side inner wing and inefficient handbrake. I decided to sort it out this evening (Working outside in the dark). I really need the Van for Sunday!!
Through my own stupidity, not having someone watch as I weld, I now need a wiring harness, Dashbord etc. Yep, I set fire to my own Transit with less than an hours work left. I've pulled the dash out and started cleaning up, luckily, I've manged to scrub the windscreen clean - it didn't crack.
I'll phone round for a dashboard tomorrow, I'm not going to let this beat me!
Down in the dumps Hightop.
hightop
Postby reaper » Fri Dec 07, 2007 3:33 pm
:shock: unlucky mate but i have to say youve done a good job upto now some would have given up way before now
reaper
Postby Luke » Fri Dec 07, 2007 9:21 pm
:shock: :( oops :oops:
what do you weld with mig or gas :?:
i once set my mk2 escort estate back seat on fire by welding in an arch - that was when i used to use gas, since going over to mig ive not had a problem - touch wood :lol:
Postby hightop » Sat Dec 15, 2007 2:59 am
I do have access to mig, tig and gas but I'm a traditionalist! I still believe Oxy Acetylene is best for strength when the metal is far from new. I'm normally careful when welding but I was very cold working outside. I guess I wasn't thinking right. It's a good job my Wife ran a hose pipe out in the nick of time. The new harness and dash are now in. Only thing left to fathom is why the oil pressure warning light no longer works. Then I'll have a look at the handbrake to see why it failed.
Not long now before I start on the fun bits - adding a second battery, fitting my tail lift etc.
More pics soon - but I couldn't bring myself to take pictures of the blackened interior. I'll leave that to your imagination.
hightop
