AlanN's MK3 V6 Day Van
Postby MrMPuk » Mon Apr 16, 2007 7:57 pm
rover wrote:Not the same van, but another Mk3 (mine if you hadnt guessed :lol: )
Rover.
Has your's got the wider axle then?
Postby AlanN » Mon Apr 16, 2007 7:59 pm
Are the end caps and the bumper blended in to look like one piece
Postby Guy88 » Mon Apr 16, 2007 8:56 pm
AlanN wrote:Are the end caps and the bumper blended in to look like one piece
There off a MK5 :wink:
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Postby MrMPuk » Mon Apr 16, 2007 9:01 pm
But the answer to the question is no.
Postby rover » Mon Apr 16, 2007 11:14 pm
Rover.
No, but with 7mm spacers the Wellers come almost out to the edge, couldnt really ask for a better fit, the wider axle would push the wheels past the edge of the arch cos the Mk3 arches have less of a protruding lip. (did any of that make sense? I've had a small Bacardi :lol: )
Rover.
rover
Postby AlanN » Tue Apr 17, 2007 8:06 am
Thanks :wink:
Re: My MK3 Day Van
Postby AlanN » Thu Oct 25, 2007 10:48 pm
I’ve got a loads of jobs that need doing on the van, but one I have been playing with or trying to, is to get the Speedo drive to read correctly after the engine change. I replaced the cog in the gearbox twice, but it still didn’t read quite right… I was then told on the forum that petrol and diesel clocks are different! A quick search on eBay didn’t find much, but what I did find is a set of white dials for the diesel 130mph clocks, printed on glossy sticky-backed paper, just cut out and fit, seemed simple enough, so out came the plastic.
Removing the clock assembly was very easy, no manual required, just a matter of removing the screws from the surrounding facial panel and steering column, then another four, which hold the clocks in to place.
I stripped down the dash assembly in anticipation of the new dials arrival, but I then had to wait several weeks for the dials to arrive, by this time, the misses was getting a bit miffed with my dash in bits on the table!
I first T-Cut the clear plastic window to remove year’s worth of scratches and grime, then removing the 2 torque bolts that hold the petrol 90mph gauge in place and fitting a second-hand diesel speedo, which I set to the original mileage.
Cutting out the new dials was easy enough, only needing a sharp scalpel blade to cut out the centres for the needle centres, it was important to make sure the hole was cut large enough or as I found, it would interfere with the needles of the clock and speedo. The needles of the fuel and temp gauges just unhooked and the speedo one pulled off easily, leaving me to carefully stick the labels on. Lastly, I replaced the bulbs with some blue LED’s and screwed the whole thing back together.
Here it is just sitting in the dash all lit up, I’ll finish everything off tomorrow and then back to my wheels. Oh, just remembered, that I painted the needels black, may do them fluoresent red. How much, LED bulbs £13.98, white dials £5.98, clocks £ 0 (thanks Guy), total £19.96
Re: My MK3 Day Van
Postby intransit89 » Thu Oct 25, 2007 11:23 pm
AlanN wrote:I’ve got a loads of jobs that need doing on the van, but one I have been playing with or trying to, is to get the Speedo drive to read correctly after the engine change. I replaced the cog in the gearbox twice, but it still didn’t read quite right… I was then told on the forum that petrol and diesel clocks are different! A quick search on eBay didn’t find much, but what I did find is a set of white dials for the diesel 130mph clocks, printed on glossy sticky-backed paper, just cut out and fit, seemed simple enough, so out came the plastic.
thats nice are the lights led? as i thought of puting some blue leds in a speedo to make it look different.
wheres the speedo white ones from :idea: :?: 8)
intransit89
Re: My MK3 Day Van
Postby AlanN » Thu Oct 25, 2007 11:53 pm
The white dials come from this guy, £5.98 including post and packing
http://cgi.ebay.co.uk/Ford-Transit-Circ ... dZViewItem
The blue LEDs came from Halfrauds £6.99 pair, but you can find them cheaper on eBay, make sure you get the 4 led type as the single leds are a bit dim
Re: My MK3 Day Van
Postby nip » Fri Oct 26, 2007 7:33 pm
mint job your doing there m8 keep up the good work :D
turbo powerd transit
nip
Re: My MK3 Day Van
Postby AlanN » Fri Oct 26, 2007 10:32 pm
Yes, the misses says Im trying, really trying!!!! :? Another weekend on the wheels and hopefully I'll get them painted without cracks...
Re: My MK3 Day Van
Postby chadmat » Sat Oct 27, 2007 12:31 am
Coming along a treat Alan, keep it up! :wink:
In a MK6 280 SWB semi hi!!!!
There you go! At last!
chadmat
Re: My MK3 Day Van
Postby DOL » Sat Oct 27, 2007 10:52 pm
very nice job your doing there alan :D
Image 1 by 1 the penguins keep stealing my sanity!!
DOL
Formerly known as Dafodol.
Re: My MK3 Day Van
Postby rover » Sat Oct 27, 2007 11:18 pm
Looking good Alan 8)
Rover.
rover
Re: My MK3 Day Van
Postby AlanN » Sun Oct 28, 2007 9:02 am
Rover, I seem to remember that you put spacers on your back wheels, did you have to change the studs and is it an easy enough job? Ive not tried the wheels yet, so im not sure what width spacer I want yet, but Im think I will have to change them.
