Getting a new Mk 1 Exhaust
Postby wardy-uk » Mon Nov 05, 2007 11:38 pm
The end of my exhaust as snaped off can I just put any one on it or do I need to find a Mk 1 exhaust
wardy-uk
Re: Getting a new Mk 1 Exhaust
Postby FredTransit » Mon Nov 05, 2007 11:57 pm
How much has fell off? Just the back box or a lot more?
FredTransit
Mk2 Trannyist
Postby wardy-uk » Tue Nov 06, 2007 12:45 am
about a foot before the back box
wardy-uk
Postby Luke » Tue Nov 06, 2007 12:52 am
just weld it up - if you cant then chuck anything on and make it fit :lol:
i dont think ive ever bought an exhaust (for a car/van of mine) ever :D
Postby baconsdozen » Wed Nov 07, 2007 8:06 am
Last time I enquired (about six months back) the rear section was still available.Usually you can modify other bits and pieces to fit anway.
I was going to start making some Mk1 dowpipes as these are the hardest parts to get hold of,I've got as far as making part of a pipe bender but other things (mainly trying to stop the council pushing my business to extinction) are keeping me fully occupied at the moment.
Burtons and others stock bends and curved sections,you have to flog your house and grandma to be able to afford to make an entire system up that way but might be a way out of a muddle.
baconsdozen
Postby wardy-uk » Thu Nov 08, 2007 6:20 pm
Im going to see if I can find a pipe a little bit bigger then my exhaust then weld it on over the brake.
wardy-uk
Postby madmark » Thu Nov 08, 2007 8:22 pm
its more than likely gone on the bend ,get the back box ,chop down the front box pipe and bring the back box and fit it near the front box and this will do the same job if you dont have the money for a new system! :wink:
Postby FredTransit » Thu Nov 08, 2007 9:16 pm
A Mk2 back section will probably fit if it helps and it's available. maybe even Mk3 from a scrappy
FredTransit
Mk2 Trannyist
Postby wardy-uk » Fri Nov 09, 2007 1:50 pm
FredTransit wrote:A Mk2 back section will probably fit if it helps and it's available. maybe even Mk3 from a scrappy
If a Mk 3 will fit that will be grate ill just get one of them :)
wardy-uk
Postby madmark » Fri Nov 09, 2007 2:01 pm
the bore is completely difrent on the mk3 much bigger! :wink:
Postby wardy-uk » Sat Nov 10, 2007 2:28 pm
madmark wrote:the bore is completely difrent on the mk3 much bigger! :wink:
Looks like I am weling it then Cheers Mark :wink:
wardy-uk
Postby madmark » Sat Nov 10, 2007 2:33 pm
mate if you use plenty of wd40 you might be able to get the back box out of the rotton pipe ,then you can move the back box before the axle this will still do the job! :wink:
Postby FredTransit » Sat Nov 10, 2007 4:36 pm
Even on the petrols?
FredTransit
Mk2 Trannyist
Postby madmark » Sat Nov 10, 2007 5:45 pm
yes fred the v4 was a smaller bore than the pinto,mind you even a pinto type system isnt cheap now! but anything can be made to fit if you have a welder! :wink:
Postby FredTransit » Sat Nov 10, 2007 6:26 pm
I didn't know that about the bore, I knew the diesel one was different bores. I bought the back section for a LWB (and had to cut it down) for our reversion SWB, for £60 new, which was fair. The LWB was the only bit in stock and it was blowing so it had to be done.
Baconsdozen put one on in the ebay section, but it's been pulled for having more than one item listed. Keep an eye out for it being re listed.
FredTransit
Mk2 Trannyist
Return to Mk 1 & 2
