temp and fuel gauges not working....help please guys
Postby Harrison » Fri Dec 30, 2005 8:30 pm
Hi all,
back again....sorry.........got a new problem this time, and before i start looking well into it i thought i'd ask your advise first.
I dont know if its due to the cold snap were having but both my temperature and fuel gauges arent working.
My fuel gauge has stopped on 1/4 full and the temp gauge doesnt move.
First thoughts: fuse , havent checked yet but any other ideas would be appreciated.
Are the gauges on the same fuse?...cos speedometer is working fine.
Also could be the same prob , but the window washer motor has stopped too.......fuse????
Thanks again in advance guys
Harrison
Postby MrMPuk » Fri Dec 30, 2005 8:37 pm
You need to give us more information like what van you've got!
Postby rallyevo3 » Fri Dec 30, 2005 8:38 pm
What year? model? engine etc.... put it on now then when the techies read the post they will have more of an idea
Ian
rallyevo3
Postby rallyevo3 » Fri Dec 30, 2005 8:39 pm
I must have been typing MrMPuk
rallyevo3
Postby MrMPuk » Fri Dec 30, 2005 8:40 pm
Yeah, I don't hang about!
Postby Harrison » Fri Dec 30, 2005 8:43 pm
ooops sorry guys.
95 m plate 2.5di transit
Harrison
Postby Harrison » Fri Dec 30, 2005 8:44 pm
forgot to say that you guys really helped me out with non starting and a dodgey clutch fit.... :D
Harrison
Postby Nighthawk » Fri Dec 30, 2005 8:52 pm
speedo is a cable operated item, so thats why it still works.
fuses are the first place to start, check them ALL, the layout chart on the fuse box lid wasn't that acurate for all models.
Nighthawk
Postby Harrison » Fri Dec 30, 2005 9:26 pm
cheers nighthawk m8........yep first port of call
lee
Harrison
