It fires right away, but when I turn on the lights it takes quite some time before they start to just glow. Like a MagLite with very bad batteries.
But if I disconnect a grey or white wire on a relay in the engine compartment, the lights is fine. This wire goes from one relay to another relay. These 2 relays is mounted below my right hand battery. They have the same shape as the light relay in my MK4 Cortina.
But when this wire is disconnected, the glowing system isn't working.
Put the wire back in, the glowing system works fine, but the lights are bad again.
Is this just a case of bad earth, or is it more likely that one of the relays needs replacement?
Any help is greatly appreciated!
