Air horns
Postby madmark » Wed Dec 28, 2005 12:56 pm
i put a issri in my mk2 bus years ago ,it was great ! but by god was it heavy! :shock:
Postby jonnyshag » Wed Dec 28, 2005 1:20 pm
yeah make sure the inverter will power the compress , check the wattich on the compress
im hoping to find a air seat from a right off cab , there quite pricey new
jonnyshag
Postby jonnyshag » Wed Dec 28, 2005 1:22 pm
FredTransit wrote:Hey jonny, do they do dee dah style air horns? Still looking for them for the amby (at the right price!). Maplins do inverters for less than £100.
whats a dee dah horn??????????? :?
jonnyshag
Postby jay » Wed Dec 28, 2005 1:25 pm
ambulance horns.........there is a cdc truck place near bury st edmunds on the A14..there are more cdc truck places as well...will post them later when home..
mk1 connect tourneo
jay
Postby madvanman » Wed Dec 28, 2005 5:40 pm
They do a triple horn set with 16 diferent settings one of which is dee dah style, they state only 24volt but my mate with the toyota spaceship has been running em on 12v for a while without any problems.
madvanman
Customised!!
Postby MRspivvy » Wed Dec 28, 2005 6:21 pm
I know its wasnt addressed to me, but its a simple matter of wiring in a relay to the air horn power circuit so the horns sound alternately.
MRspivvy
Postby FredTransit » Wed Dec 28, 2005 11:22 pm
How's that work MRs? Do you need two compressors?
FredTransit
Mk2 Trannyist
Postby FredTransit » Wed Dec 28, 2005 11:23 pm
woops, two posts in a row! Are those hors you mentioned from CDC MVM? I will take a look if so.
FredTransit
Mk2 Trannyist
Postby jonnyshag » Wed Dec 28, 2005 11:47 pm
cdc website http://www.truckstuff.co.uk take a look ,ive had loads of stuff from them :)
jonnyshag
air horns
Postby MRspivvy » Thu Dec 29, 2005 2:41 pm
no, you only need the one air supply. the horn operates by a solenoid opening a valve to let the air through, one solenoid on each horn. the relay alternates the power supply to each solenoid, so they sound in sequence. I had this set up on a scania 113 many years ago, CDC or someone similar should be able to sell you the appropriate electronics.
MRspivvy
Postby madvanman » Thu Dec 29, 2005 3:19 pm
yes they are:
Triple Freight Horn :- https://store.truckstuff.co.uk/_4A56B28 ... airhorns/#
madvanman
Customised!!
Postby FredTransit » Sat Dec 31, 2005 6:15 pm
Thanks MVM, I can only see a triple set without different setting though. Are those the one you mean?
FredTransit
Mk2 Trannyist
Postby madvanman » Sun Jan 01, 2006 6:26 pm
FredTransit wrote:Thanks MVM, I can only see a triple set without different setting though. Are those the one you mean?
this set (last one on the page):
24v only. This is a three horn set made to imitate an American freight train whistle. It is installed with a seperate switch which can be used to change the sound. NOW ONLY £45.00
madvanman
Customised!!
Postby FredTransit » Sun Jan 01, 2006 6:46 pm
Thanks MVM, it doesn't mention a compressor, so I suppose I would have to get one seperately. There doesn't seem to be any on the CDC site, but I would think a 12v would be easy enough to get.
FredTransit
Mk2 Trannyist
Postby madvanman » Sun Jan 01, 2006 6:56 pm
There designed to work off a trucks air supply but will work ok from a standard air horn compressor as long as the compressor and horns are powered at the same time.
madvanman
Customised!!
cron
