connect clutch
connect clutch
Postby belly » Tue Dec 04, 2007 9:47 am
Sorry guys another connect question :roll: my cluth pedal seems very slow at returning after ive changed gear comes back some of the way then returns fully after a delay :( i thought maybe a weak cable but someone said its a hydraulic system ? does any one know as it only done 19k and is still under warrenty 8) ive got no probs with selection or slipping tho! other than that its a great little van very happy so far 8) turning circle is bigger than my old swb mk6 tho figure that :lol:
belly
Kaiser Chief
Re: connect clutch
Postby motorwise » Tue Dec 04, 2007 11:37 pm
may need a bleed but as it's still under warranty let your agent sort it for you
http://www.motorwise.net
motorwise
Re: connect clutch
Postby Nighthawk » Tue Dec 18, 2007 10:10 pm
The clutch is a hydraulically operated system, if the pedal is sticking down after it's been pressed I think it could be one of 2 things.
lack of assistance from the return spring, this can be down to the bushes being dry/split or the spring is weak.
try a squirt of wd40 on the top of the pedal.....not too much though as you don't want to be slipping off the pedal.
Master cylinder internal piston concern, stopping the piston from returning back along to it's rest position,
that'll need a new cylinder.
Transit.........Job done
Nighthawk
