None starting V4
Re: None starting V4
Postby FredTransit » Mon Dec 10, 2007 5:07 pm
Just seal up the holes in the top of the filter housing with silicone!
FredTransit
Mk2 Trannyist
Postby wardy-uk » Mon Dec 10, 2007 5:12 pm
FredTransit wrote:Just seal up the holes in the top of the filter housing with silicone!
Its a bout a 4 inch hole I will try weld it up this week
wardy-uk
Postby FredTransit » Mon Dec 10, 2007 7:00 pm
Cut a disc off a coke can, and stick it down with said silicone sealer. Here's one i made earlier.... :wink:
FredTransit
Mk2 Trannyist
Postby wardy-uk » Mon Dec 10, 2007 7:02 pm
I can not see a photo Fred. I will just stick to welding mine up :)
wardy-uk
Postby FredTransit » Mon Dec 10, 2007 7:08 pm
FredTransit wrote:Cut a disc off a coke can, and stick it down with said silicone sealer. Here's one i made earlier.... :wink:
I meant as per Blue Peter, making stuff! :lol:
FredTransit
Mk2 Trannyist
Postby wardy-uk » Mon Dec 10, 2007 7:09 pm
:lol: Ill post a pic of mine when welded then
wardy-uk
Postby madmark » Mon Dec 10, 2007 7:35 pm
:shock: :shock: dont weld it fibreglass it! :wink:
and running without a air filter you are asking for big trouble ,you are lucky you still have the camper ,v4 engines were allways backfireing through the carb :shock: how its not gone up in flames you are lucky!
Postby wardy-uk » Mon Dec 10, 2007 7:41 pm
madmark wrote::shock: :shock: dont weld it fibreglass it! :wink:
Mine is metal hence hence the rustly hole I would assume its the right one to as my ice cream with a V4 had one. The original engine in my camper had one and there was one with engine I bought :?
I think I will be puting it on tomorow then so i don't go up in flames! :lol:
wardy-uk
Postby rottie_007 » Mon Dec 10, 2007 8:06 pm
mine used to pop through the carb a bit till I sorted the tappets...
noe it runs evenly but ticks a bit...
one day with practise ill be able to get them quiet im sure lol
1979 mk2 pre facelift CI campervan " Bessie Brown "
1994 Pug 405 est " George "
1998 pug 106 "Mildred"
rottie_007
Postby FredTransit » Mon Dec 10, 2007 8:50 pm
I think mark meant don't weld it, repair it with fiberglass. He's right about the carb too, this happened to us with the first Mk1 we had, luckily it was put out before too much damage was done, and she passed the MOT than afternoon!
FredTransit
Mk2 Trannyist
Postby baconsdozen » Tue Dec 11, 2007 1:43 pm
Quite a few fords with V4s caught fire with carbs back firing, the hollow sections cast into the manifold can fill with fuel and oil and that hardly helps the resulting fire.When I bought Tarquin the transit it had a rusty air cleaner and I modified the air cleaner and welded a plate covering the whole top.I did the same thing on Courtenay the camper.If more than a fer drops of water get into the manifold whilst the vehicles parked its possible to get hydraulic lock when turning the engine over or when it first fires,if your lucks bad it might be enough to bugger it up for good.
Running without an air cleaner isn't none to clever with any engine,but on a V4 where mixture distribution is already uneven it might weaken the mixture enough to cause serious problems.
baconsdozen
Postby wardy-uk » Wed Dec 12, 2007 12:08 am
baconsdozen wrote:Quite a few fords with V4s caught fire with carbs back firing, the hollow sections cast into the manifold can fill with fuel and oil and that hardly helps the resulting fire.When I bought Tarquin the transit it had a rusty air cleaner and I modified the air cleaner and welded a plate covering the whole top.I did the same thing on Courtenay the camper.If more than a fer drops of water get into the manifold whilst the vehicles parked its possible to get hydraulic lock when turning the engine over or when it first fires,if your lucks bad it might be enough to bugger it up for good.
I will be getting that air filer on tommorow. I have never used glass fiber is an easy thing to do?
wardy-uk
Postby madmark » Wed Dec 12, 2007 6:28 am
its great stuff ,go and get a tin of P40 then mix it up with the hardner suplied then put it on the air fillter pan ,if you want a good finish or to stop it going every were you can use a plastic bag on the underside so it sticks to that and then when it dries peel the bag off and there you go a nice finish and very strong as well! :wink: :wink:
Postby wardy-uk » Wed Dec 12, 2007 10:01 am
I will do it today and post the results here cheers Mark :wink:
wardy-uk
Postby madmark » Wed Dec 12, 2007 3:57 pm
:lol: at the end of the day it doesnt matter what it looks like as long as it does the job of keeping the carb cleen! :wink:
Return to Mk 1 & 2
