Voltage panel meter
Voltage panel meter
Postby sam l » Fri Dec 14, 2007 12:55 pm
Hi, I'd like to stick a meter in the van to tell me how many volts are currently (sorry!) residing in my battery. I bought one from ebay but it doesn't seem to work, cycling through a large range of unlikely sounding voltages when I stick the red and black wires on the respective bits of my jumpstart box. Then in got hot and started to smell. It has 5 jumper switches on it but they don't seem to do anything much except change where the decimal point goes. Anyone know where I can get one that works? I know in old landies they had ones with a needle, this is what started me off on this cos I always seem to have a knackered alternator and would like to know when to bring the battery in for a top up!
Thanks,
Sam
sam l
Re: Voltage panel meter
Postby dcwuk » Sat Dec 15, 2007 1:30 am
'I have opinions of my own -- strong opinions -- but I don't always agree with them.'
-George Bush
dcwuk
Postby evanmandos » Sat Dec 15, 2007 1:59 am
volt meters don't cost much, just go to a radio shack/conrad/electronic partner or whatever its called in the UK :P any volt meter which at leat measures 14V will be OK. If you'd really like it to look nice, get an old army transceiver and use the 'S-meter' of it, fiddle a bit with a resistor in front of the meter(+ side) to get the scale to line up with your battery voltage(so 12 on the meter is average battery voltage), looks awesome costs a pound :P
only plus of a car-voltage meter is that it fits in standard dashboard brackets from the car-accesoires shop.
Personally i think 20 pounds(about 30 euros isnt it) is a bit expensive since they cost about 50p if you buy standard volt-meters in bulk :P
evanmandos
Return to Mk 1 & 2
