None starting V4
Re: None starting V4
Postby wardy-uk » Wed Dec 12, 2007 4:12 pm
I have got some and will have a go tommorow :) I hope I can make it look good :)
wardy-uk
Postby wardy-uk » Sat Dec 15, 2007 3:24 pm
I'm having a lot of trouble starting my van when it' cold and wet :?
The engine is turning over but she just wont start :evil:
Anyone got any tips or ideas???
William
wardy-uk
Postby steady72 » Sat Dec 15, 2007 3:31 pm
FULL service?plus a carb overhaul.
steady72
Postby wardy-uk » Sat Dec 15, 2007 3:50 pm
Is there any thing I can do just now as I need it to get me to work in 2 hours :?
wardy-uk
Postby madmark » Sat Dec 15, 2007 4:49 pm
:? take the dizzy cap off and make shure cits dry and cleen ,when was the last time it had ,pionts,rotor arm ,dizzy cap ,condencser???? :?
Postby wardy-uk » Sat Dec 15, 2007 4:56 pm
Its fry and clean its never had them in my time look like I am buy some tommorow!
wardy-uk
Postby madmark » Sat Dec 15, 2007 5:01 pm
:shock: :shock: nowonder it runs like a bag of poo! :lol: :lol:
Postby wardy-uk » Sat Dec 15, 2007 5:03 pm
I just wish I could get it to start now I have to leave here in 40 minites and it will not start :(
wardy-uk
Postby captain hook » Sat Dec 15, 2007 6:18 pm
Swan Vestas.............. :)
captain hook
Postby steady72 » Sat Dec 15, 2007 6:27 pm
wonder if he got it started, bet he wishes it was a di now!!!
Wardy, bring it to me and il look it over for you. Show you what it needs for a service to make it semi reliable.
If you get a head gasket set and bolt set i'll help you strip the heads and bed the valves in and do the oil seals and timing etc. I'll help, but your geting dirty. If your gonna go around saving fords finest I'd better turn you into a mechanic!
Anything for a quiet life lol.
steady72
Postby wardy-uk » Sat Dec 15, 2007 6:31 pm
Nope I never :evil:
That would be good if you could :) I don't mind getting my hands dirty :) The past 5 months it ran ok just these last couple of weeks in the cold its had problems.
wardy-uk
Postby Neil » Sat Dec 15, 2007 6:34 pm
5 months :!: thats a v4 record :lol: :lol:
Neil v6
Neil
Postby wardy-uk » Sat Dec 15, 2007 6:41 pm
Neil wrote:5 months :!: thats a v4 record :lol: :lol:
:shock: :lol:
wardy-uk
Postby steady72 » Sat Dec 15, 2007 7:01 pm
ok,a quick run down on how to start an old ford that can't be bothered.(this is tongue in cheek)
Guys feel free to comment or add bits in here.
This assumes there’s one specific thing wrong and its not just a combination of everything being past its best or out of tune.
1/go put the kettle on.
2/ pull your spark plugs out and clean them. Put them back in .Do this one at a time so as not to mix up your timing. Then take off your dizzy cap and check your points. Check the gaps, rotate your engine and wait until the dizzy opens your points. This will be when the cam in the dizzy operates your points. Check your gap size and make sure the points are clean.
3/ Go make a cup of tea. Milk and one sugar for me, unless it’s a decent sized cup then make it 1 and a half. Oh and its essential to use quality parts here, Tetley or nothing. Failure to use quality arts may result in total failure and me going of to watch tv.
4/take the air filter off( assuming you have one on!) and operate the throttle, can you see any sign of fuel being injected into the engine?
5/Run around to the cab like an idiot and try and start it.
6/If it runs great, look all smug and take your cup back into the kitchen bragging about how cool these old vans are to work on. if not go to step 7.
7/ pour a cap full of fuel down the carb. Preferably the type your vehicle runs on.
8/ run around to the cab like an idiot and try and start it. If it starts and runs ok go to step 6 and plan on a carb rebuild. If it starts and dies after a few seconds then go have another cup of tea and tell everyone these old vans need specialist care.
9/ get a taxi
10/Then find someone to rebuild your carb and set up your engine while taking kudos for knowing when to get the experts in.
11/ if nothing happens when the key is turned with fuel down the carb you need to find your spark.
12/ I’m bored now.
If all of them either have no effect then its probably a combination of everything, eg you need a good tune and service.
steady72
Postby madmark » Sat Dec 15, 2007 7:06 pm
steady72 it would be good if you could give will some lessons then he will have a idea! :wink:
Return to Mk 1 & 2
