V4 engine stud patten!!
Postby Luke » Sat Apr 09, 2005 10:07 pm
Can anyone answer this question:-
Is the english V4 bellhousing bolt patten the same as V6 2.8 and 2.9 engines :?:
its the same as the V6 3.0 im told!!!
Postby madmark » Sun Apr 10, 2005 12:27 am
luke no no mate they are not ,completly difrent ! v4-v6 essex one type cologne v4-v6 other type! my gearbox in the mk1 will take 2.3-2.8-2.9 but not essex ! thats why i cant just through in a 2ltr essex v4,without the gearbox belhouseing clutch fork etc! so i would need a engine and gearbox and probly prop as well! :cry:
Postby Luke » Sun Apr 10, 2005 12:31 am
thought you might know mark :lol:
Its just me and Bob S were pondering today i have an adapterplate from pinto to what i thought was mt75 but i thought all mt75s including petrol ones were Di stud patten - am i wrong???
are all mt75's the same bellhousing pattern :?:
if so what's this adapter plate off??
Postby madmark » Sun Apr 10, 2005 12:36 am
mate same patern i belive there is a slight difrence in the boxes from di to petrol not shure what way round??? transit geoff might know ! was the plate off of a pinto?????
Postby Luke » Sun Apr 10, 2005 12:38 am
yeah mate plate was off a pinto!!!
Postby madmark » Sun Apr 10, 2005 12:39 am
have you got a mt75 kicking around anywere? one thing i have always wonderd could the add plate be drilled to take another engine ie 2.8? fords do use a add plate for the 2.9 to mt75 but getting one of those down the scrappy is like rocking dung!
Postby bortaf » Sun Apr 10, 2005 12:41 am
seen a 2.9 ambulance with an MT75 box but no idea weither it had a plate or not, my di recovery has no plate but my 2.0 pinto Mk3 does so assume they are all di bell housing pattern and need an adaptor to fit a pinto/DOHC.
Current fleet
Mk7 transit ambulance
Mk1 Mondeo 1.8 STD
Mk5 fiesta 1.25
Mk6 fiesta 1.4TDCi
bortaf
Postby madmark » Sun Apr 10, 2005 12:41 am
i am rackking my small brain ,shure i have seen a add plate on a pinto but on another type gearbox cant remember!
Postby bortaf » Sun Apr 10, 2005 12:43 am
My Mk2 has an adapter with a type 9
Current fleet
Mk1 Mondeo 1.8 STD
Mk5 fiesta 1.25
Mk6 fiesta 1.4TDCi
bortaf
Postby madmark » Sun Apr 10, 2005 12:44 am
bortaf you are write mate! the 2.9 uses a plate i think ford sort of tried keeping the boxes mostly the same just used plates,its strange how they never fitted a mt75 to a essex v6 they used overdrive! :?
Postby Luke » Sun Apr 10, 2005 12:44 am
yep ive got a mt75 in the shed, ive also got pinto bellhousing and v6 2.8/2.9 bellhousing- threw a V4 one away!! Doh!!! though bobs bringing one round next week hopefully to try!!
the mt75 i have is a Di one though!!!
this adapter plate may be we think to V4!!!
I dont think it will adapt to V6 2.8 cos the bolts look too close!!
what i need is a petrol Mt75 to check!!!
:D
Postby madmark » Sun Apr 10, 2005 12:46 am
are maybe if thetop bolt holes are close at the top it will be the same as 2.8? but you said it did come from a pinto didnt you???? :D
Postby Luke » Sun Apr 10, 2005 12:51 am
yep its still on the pinto now - but its not to Di or V6 2.8!!!
Postby madmark » Sun Apr 10, 2005 12:51 am
bortaf well done mate you have joged my memory , the add plate was fitted to type 9 pinto wile the non heavey duty box f type had a bellhoseing that went direct to the engine! so luke there is a good chance that plate is for pinto to type 9 or g type 4 speed maybe!
Postby madmark » Sun Apr 10, 2005 12:53 am
any idear were the engine came from ????
