by dredds » Thu Jan 10, 2008 10:07 am
Morning all...
I am having trouble starting the old bus. I have burnt out one starter. Isn't the bit the +ve supply goes into called the ballast resistor? This smoked whilst winding and then it packed up.
I have fitted a replacement from a breakers yard and whilst it started OK the first time whilst being jumped from another vehicle, when being started on its own, the engine winds and the ballast resistor gets hot and starts smoking. I have stopped trying in case I burn this one out completely as well.
The fact that it winds for so long could be due to perishing fuel pipes and I plane to sort those out soon, but it has always started eventually in the past, now it wo't.
Any ideas??
Kevin.
1985 Mk2 with early 2.5DI...
PS jave just put a deposit down on a 54 plate 260 SWB Medium Roof Van TDi, so HOPEFULLY the bus can be retird into social uise only!
