Headlight stalk to head light switch??
Postby doughythevanman » Sat Jan 26, 2008 11:20 pm
Having a mad idea weekend and after some thought have decided to try and fit a headlight switch ( MK6 / 7 ) into my dash and do away with the headlight stalk. :idea: Has anyone ever tried this and how easy do you think it would be. I assume it would be a case of wiring only as the switch can be fitted to the dash easy enough. Any advice would be very helpful on whether it is possible.
P reg SWB Semi high top
S reg LWB 190 Semi high top
Range Rover TD6
Volvo S80 D5
doughythevanman
Re: Headlight stalk to head light switch??
Postby Guy88 » Sat Jan 26, 2008 11:31 pm
should be possible, you'd have to cut the original off and then you'd be left with a hole
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Postby doughythevanman » Sat Jan 26, 2008 11:34 pm
was thinkin about that and may have a parctise to see if i can blank it with a bit off another cut to size, glued from inside and a little touch up. Only thought after seeing the led conversion on them and thought it looked the dogs danglies! 8)
Is there a wiring diagram on here anywhere for the light stalk or do you know where i can get one??
Range Rover TD6
Volvo S80 D5
doughythevanman
Postby Guy88 » Sat Jan 26, 2008 11:44 pm
doughythevanman wrote:was thinkin about that and may have a parctise to see if i can blank it with a bit off another cut to size, glued from inside and a little touch up. Only thought after seeing the led conversion on them and thought it looked the dogs danglies! 8)
Theres all sorts of wiring diagrams on the TIS disc.
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby doughythevanman » Sun Jan 27, 2008 12:01 am
Cheers Guy! :D
Range Rover TD6
Volvo S80 D5
doughythevanman
Postby motorwise » Sun Jan 27, 2008 7:37 pm
you'll be able to do away with the rear fog lamp switch as well :D
http://www.motorwise.net
motorwise
Postby transitgeoff » Sun Jan 27, 2008 7:40 pm
bout the wipers and squirter :?:
transitgeoff
Postby motorwise » Sun Jan 27, 2008 7:41 pm
transitgeoff wrote:bout the wipers and squirter :?:
prolly just going to saw off the light stalk :D
motorwise
Postby Luke » Sun Jan 27, 2008 7:44 pm
tbh i quite like the light stalk ever since i had my 1st mk2 escort :lol:
doesnt the mk6 one have the parking feature when you turn it anticlockwise :? :?:
Postby transitgeoff » Sun Jan 27, 2008 7:56 pm
no
transitgeoff
Postby doughythevanman » Mon Jan 28, 2008 6:20 pm
i will be leaving the other stalks on unless i can find a way to change. Was actually debating using the stubby type stalks as i am looking into a aftermarket steering wheel and it will look a lot tidier. The only problem is i would also need the casing so will have to wait and see. What do you guys think?? If not the hacksaw is coming out!! :lol: :lol: :lol:
Range Rover TD6
Volvo S80 D5
doughythevanman
Postby Luke » Mon Jan 28, 2008 8:54 pm
if you fit a smaller wheel they will suit it :D when i had the small dia wheel on mine the sticks did look too big - i was gonna swap em for escort ones but swapped the wheel back as it obsqured the speedo :lol:
and i didnt have pas :lol:
Postby doughythevanman » Mon Jan 28, 2008 10:42 pm
to be honest luke i dont really pay too much attention to the speedo :lol: so wouldnt be an issue. I have a set of orion stubbies from an old car so may just put them on and see what it looks like first. When you changed your wheel did you have to buy the boss seperate and where did you get it from? Have seen the wheel i want but they dont do the boss for it? :?
Range Rover TD6
Volvo S80 D5
doughythevanman
Postby Luke » Mon Jan 28, 2008 10:53 pm
whats the wheel you want :?:
i used a pukka transit boss for a mk1/2 and ground down the raised spline! but a mk1 escort or capri boss works in the same way :D
Postby Luke » Mon Jan 28, 2008 10:55 pm
here's a couple of pics of it in :D the pics make the stalks look ok but in 'real life' the felt odd :lol:
cron
