U Bolts
U Bolts
Postby dredds » Sun Feb 03, 2008 12:59 am
Gents...
I need a pair of U bolts for the rear leaf springs of my 1985 Mk2 bus. Ford are having trouble getting hold of them, the ones they have managed to get are too long.
Any ideas of part numbers? Or does anyone have a pair they would like to sell??
dredds
Re: U Bolts
Postby FredTransit » Mon Feb 04, 2008 3:19 pm
Try a commercial spring manufacturer. In London there is a company called Paddington Springs, they made some of our springs, maybe they would do mail order for the U bolts.
FredTransit
Mk2 Trannyist
Re: U Bolts
Postby comet » Mon Feb 04, 2008 11:59 pm
when i replaced rear springs on my mk1, i used flat plated drilled the four holes put them on top of springs and used 6 inch nuts and bolts,no probs with mot all worked ok, did the same with front when i put extra leaf in spring,
1971 LANDLINER - 2.5DI FITTED NEW BY FORDS IN 2000 - IF YOU WANT A COVER UP ASK THE POLICE THEY ARE THE BEST
comet
Re: U Bolts
Postby baconsdozen » Tue Feb 05, 2008 9:28 am
Jones springs (there's a link here)http://www.baconsdozen.co.uk/motorhome/transit.htm make U bolts to pattern as do Owens (link in same place).
baconsdozen
Re: U Bolts
Postby Smooth Hound » Tue Feb 05, 2008 5:45 pm
you may get some from a landrover place, i think they are pretty much the same
'94 L Reg 2.5Di LWB high top
Smooth Hound
Re: U Bolts
Postby dredds » Wed Feb 06, 2008 1:22 am
Thanks all... Comet - that was going to be my last resort.
However, speaking to another assistant at the local Ford garage has turned up the proper article, and half the price of what I had previously been old!
Result!
dredds
Return to Mk 1 & 2
