mk1 master brake cylinder replacement
Postby walker tranny » Tue Feb 19, 2008 5:51 pm
can l fit a mk3 transit master brake cylinder to my mk1 as the seal in mine have went or is it a big job or can it be done cheers steve
walker tranny
Re: mk1 master brake cylinder replacement
Postby Neil » Tue Feb 19, 2008 7:40 pm
you can buy seal kits :!:
Neil v6
Neil
Postby walker tranny » Tue Feb 19, 2008 8:13 pm
from were and how much
walker tranny
Postby wardy-uk » Wed Feb 20, 2008 11:59 am
I have a Mk 3 Servo and master brake cylinder fitted to mine. I got a garage to do it only tuck him about 15 minites.
wardy-uk
Postby FredTransit » Wed Feb 20, 2008 2:35 pm
wardy-uk wrote:I have a Mk 3 Servo and master brake cylinder fitted to mine. I got a garage to do it only tuck him about 15 minites.
Interesting, cos if you fit the Mk3 to a Mk2 (and we have, loads of times) you usually have to adjust the push rod to the cyl that the pedal is attached to. Did they do anything like that, or just fit it and you were off?
FredTransit
Mk2 Trannyist
Postby wardy-uk » Wed Feb 20, 2008 4:50 pm
Fred, yes they had to put a bigger bit of pipe over the rush rod but it did not take them long.
wardy-uk
Postby Luke » Wed Feb 20, 2008 7:26 pm
also i think the mounting hole centres are different :)
Postby FredTransit » Wed Feb 20, 2008 8:00 pm
the Mk3 servo dips slightly to the driver's side, but works just fine.
FredTransit
Mk2 Trannyist
Postby comet » Wed Feb 20, 2008 8:59 pm
1971 LANDLINER - 2.5DI FITTED NEW BY FORDS IN 2000 - IF YOU WANT A COVER UP ASK THE POLICE THEY ARE THE BEST
comet
Postby hodgson4711 » Sat Feb 23, 2008 11:07 pm
the kit on e-bay has ended but this one on e-bay may help no. https://www.ebay.co.uk/itm/260213865251 they said it was new.
hodgson4711
Postby baconsdozen » Sun Feb 24, 2008 1:03 pm
Luke wrote:also i think the mounting hole centres are different :)
They are.
baconsdozen
Postby walker tranny » Mon Feb 25, 2008 3:57 pm
l,ve just fitted a mk4 one working ok thanks
walker tranny
Postby hessey50 » Wed Mar 05, 2008 7:15 pm
just fitted a mk3 servo and cyl to my mk2 4bolt to two bolt re-drilled holes in and welded up mounting bracket to retain strength mk 2 rod cut off old full of fluid servo and welded to cut down 3 rod to get length of rod to pedal correct, now stops as it should, I find having brakes less exiting driving but anything for a quiet life.
hessey50
Return to Mk 1 & 2
