We need axle info!!!
Postby dangeeeeerousss » Fri Jul 28, 2006 3:23 pm
fabricating shock mounts wouldnt be a problem im just weighing up all my choices of getting my wheels on cheapest way really but what about the fronts i was thinking a long the lines of a like £20 donor car and transfering the running gear over
but that has widened my opions a bit as long as the front could be done to i was think of the weight issue even though it will never carry excess weight as its used as a car rather than van
thanks
dangeeeeerousss
Postby Luke » Sun Jul 30, 2006 9:57 am
can anyone identify this 75x45 hole centres click here for pic of axle flange :D
what axles have this flange :?:
Postby dangeeeeerousss » Fri Aug 11, 2006 5:02 pm
fate!! whilst down at my mate the transit breakers today. after searching most of the day for parts.
an old mk3 petrol comes trailered in so like a fly round sh%t i fliy straight over to it and underneath to check the prop out to see if it was the one i was after but no joy :cry:
so i climb in side to see what salvagable bits i can scavenge :lol:
i see part of a prop buried under loads of crap and it turns out to be my original 2.0 efi prop that i snapped and threw away 6 months ago!!!
now heres the next bit not had chance to get to my van yet .
as its only the rear half of the prop i need and they split in two at the bearing will this rear half connect to the other prop that i now have!!!!
which is a normal prop this prob dont help but nearly every van ive checked in the scrappies all seem to have this prop on
if thats not too confusing lol
dangeeeeerousss
more diff info
Postby raceboysparkey » Wed May 30, 2007 7:12 pm
:?: this is all good stuff but can some one say what diff ratios gos to what engine size,what year and model :?: :?: :?:
raceboysparkey
Re: more diff info
Postby AndyG » Wed May 30, 2007 8:08 pm
raceboysparkey wrote::?: this is all good stuff but can some one say what diff ratios gos to what engine size,what year and model :?: :?: :?:
You can have several options for the same engine :!: :( So there isn't a simple answer to your question :(
Re: more diff info
Postby MrMPuk » Wed May 30, 2007 10:30 pm
What do you need to know would be better!
Postby rottie_007 » Wed Jul 04, 2007 10:37 pm
dunno if tis relevant
ford landliner twin wheel 1975 fitted with 5.143:1 axle when converted by CI
1979 mk2 pre facelift CI campervan " Bessie Brown "
1994 Pug 405 est " George "
1998 pug 106 "Mildred"
rottie_007
Re: We need axle info!!!
Postby manandvan » Tue Dec 11, 2007 7:00 pm
right axles: type 32 single wheel salisbury looks like capri axle and uselessly weak for a transit, type 34 square casing type swb axle, wider on the later variants as already pointed out, type 51 basically same as type 52 but single wheel, type 52 twin wheel axle, mk 1 2 3, type 53, old ford a series axle does not fit transit! (different shackles and very low 5.8 ratio!) as a rule of thumb on twin wheel, most chassis cabs where 5.1 ratio and panel vans 4.63 plenty more info for those who need it.
manandvan
Postby Sundowner » Fri Dec 14, 2007 11:31 pm
The old volvo dana 30 is a damn strong unit, has 27 spline axles can be had in both LSD and oped 4 pinion
Yeah i know its big green and rusty so move your Porsche before i bash it with 460 cubes of fords finest cast iron
Sundowner
Postby tr1cky » Fri Feb 22, 2008 6:34 pm
I have a '96 mk5 100 lwb, according to the VIN its fitted with the 34 timken no LSD rear axle with the 4.56:1 Diff.
its a single wheel
If thats of any use to anyone?
1996, N reg, 100 LWB, 70ps Di
tr1cky
Postby zedy1 » Tue Apr 01, 2008 11:58 pm
Ive seen a 190 single wheel flat bed chassis cab, what would be the axle ratio on the truck, reg numer r901dtu
zedy1
Postby tim the grey » Thu Apr 10, 2008 1:25 am
:shock:
Having spent the best part of the last 15 years writing both the PARTS CATALOGUE, and more importantly, THE PREFACE for the Transit, all I will say here is...
Don't ask!
Axle specs changed regularly, and not just on facelift/new models.
As to any sign of there being a common axle fora spec? Forget it, the idea is the CUSTOMER specifies the van they want...
I'll see if I can cop a copy of the preface files for the Transit from 86/92/95/2000/2006. That way, assuming some clown hasn't been messing, you can tell what Ford fitted in the first place.
Oh, and don't ask ME anything clever, I retired 6 months ago, and I've forgotten most of it!
I really DID write the book...
tim the grey
Postby snakemaster » Sun Jun 08, 2008 11:50 am
i have had a good look on the forum and could not find the info
ie is the mk1 mk2 rear axle G type 53 the same i no the rear springs are not the same,
well i got a tape out and the twin wheel G type 53 axles on the mk1 and mk2 are the same
Wanted manta A front spoiler , i now theres one out ther for me
snakemaster
Postby cyberchild » Thu Jun 19, 2008 10:13 pm
I need help with this one !! it`s a mk3 1986 pickup single wheeled 6 studs axle. with lemmers rims... are this normal? i`ve never seen this axle before and i cant find rims on internet too.
cyberchild
Postby snakemaster » Mon Jun 23, 2008 11:59 pm
i have got 2 off those gay boys rims with good tyres at the house came off a 2.0 pet lwb f reg van 5.0 diff , dumped the axle with the rest of the sh*t (mk3 transit)
ps nice flipflop infront off the rim :lol: :lol:
snakemaster
