Pinto wrote:Sound like a vapour lock in the fuel system or fuel rail to me.
How close do the fuel lines go to the exhaust system ? Is there any source of excessive heat anywhere near the fuel rail ?
could also be a blocked filter in the fuel pump, or an obstruction in a fuel line ?
rover wrote:What year is the Van?
If it has a mechanical fuel pump (Pinto engine) then fitting an aftermarket electric pump will probably cure it, if its a dohc engine then it may just need a new fuel filter, possibly the injection relay is acting the prat, or more expensively a new injsection pump.
Rover.
