Anyone know anything about overdrive gearboxes ?
Postby danny allen » Mon Jan 23, 2006 2:31 am
Hi
I have an e reg ( mk3 ? ) transit 2.5D and its fitted with a 4 speed overdrive box, however the overdrive wire in the gear stick has been cut/broken. The wire has been lost and i wondered how to connect tis bck up?
Does on wire go to a live and the other to a swirched earth?
How do i use my overdrive?
Do i need to clutch it when im turning it on?
any help appreciated
thanks
dan
danny allen
Postby FredTransit » Mon Jan 23, 2006 2:44 am
I have an OD box in a Mk2 minibus, and I don't know about installation, but the OD will not engage in 1st and 2nd, and you have to switch it in in 3rd or 4th, and switch it off when changing down. I am still getting used to the box myself, and occasionally forget to switch it off when changing down, it doesn't seem to have damaged it (yet!). To be honest I only use it on A roads and motorways and drive it as a 4 speed elsewhere as switching the OD on and off gets a bit much round town. Hope this helps.
FredTransit
Mk2 Trannyist
Postby baconsdozen » Mon Jan 23, 2006 12:09 pm
If you have a look underneath at the solenoid you should see if one of its wires is connected to earth.If it is the switch in the gear knob supplies a live feed which goes to the solenoid via cut out switches.The feed should be cut in 1st and 2nd gear and VERY importantly in reverse.If the vehicle is driven any distance at all in reverse with the OD engaged it will be smashed beyond repair.If in doubt pull the wires off the solenoid and subtitute a bulb,if it only lights in 3rd and 4th you should be OK.OD units are designed to engage and disengage with power going through them but it helps ensure long life if it is done with a low throttle opening and disengagement is carried out at relatively low speed to avoid over revving the engine.
baconsdozen
Postby danny allen » Mon Jan 23, 2006 7:56 pm
thanks for your help guys
it looks like there was once a wire from the gearknob, only the one though.
Would this be the earth?
danny allen
Postby stevew » Tue Jan 24, 2006 3:10 am
There's usually two wires. In fact all that I've seen have used a piece of two core mains cable :lol: even the Ford fitted ones! :shock:
I don't have one myself so best to listen to someone else!
Steve
stevew
Postby danny allen » Tue Jan 24, 2006 7:13 pm
mmmmm ill have another look at the weekend
danny allen
Postby danny allen » Wed Jan 25, 2006 11:40 pm
so do i change
clutch
1st
clutch
2nd
clutch
3rd
flick button on
flick button off
clutch
4th
flick button on
is that right guys?
danny allen
Postby MrMPuk » Wed Jan 25, 2006 11:42 pm
I never really see much point using the overdrive between 3rd and 4th.
Postby danny allen » Thu Jan 26, 2006 1:49 am
ok
its never worked on mine so i just wondered :)
danny allen
Postby FredTransit » Thu Jan 26, 2006 2:09 pm
MrMPuk wrote:I never really see much point using the overdrive between 3rd and 4th.
I only use mine in 4th too.
FredTransit
Mk2 Trannyist
Postby bazw » Thu Jan 26, 2006 2:32 pm
3rd od would be for those pesky hills where you cant quite run in 4th and rev to high in 3rd
350L Series 56 plate
2.4 duratorq 115 ps
A.R. 4.27
bazw
