Chassis cab lengthening
Postby mike730 » Sat Jan 21, 2006 9:04 pm
I want to add about three foot into my 96 crew cab chassis cab to increase the wheelbase before I add a recovery body,I was wondering if anyone knows of where I can get hold of some fabricated sections that will overlap the original chassis sections.
mike730
CHASSIS LENGTH
Postby john leeman » Sat Jan 21, 2006 10:00 pm
I AM SURE YOU ARE NOT ALLOWED TO INCREASE YOUR CHASSIS MORE THAN 1/2 WOUR WHEEL BASE. CHECK FIRST, GOOD LUCK
35 years of driving,repairing,sleeping in transit's lovin every minute.
john leeman
Re: CHASSIS LENGTH
Postby Luke » Sat Jan 21, 2006 10:06 pm
john leeman wrote:I AM SURE YOU ARE NOT ALLOWED TO INCREASE YOUR CHASSIS MORE THAN 1/2 WOUR WHEEL BASE. CHECK FIRST, GOOD LUCK
what about them limo's then john? they must be 3 times the origanal wheelbase :lol:
Postby 100ps_drw_hicube » Sat Jan 21, 2006 10:06 pm
try a scrappy as there were elwb chassis cabs with bolt on extensions not sure how long they were but were at least 2 ft i think :D
100ps_drw_hicube
Transit Abuser!!
Postby FredTransit » Sun Jan 22, 2006 12:17 pm
Hi Mike, I am not too sure about Mk3s, but you may still be able to get the extention plates from Ford. When they are done as an option, the standard chassis were taken off the line and cut then re jioned with big plates, we have 4 Mk2s (earlier than yours) that are Ford extra LWB, and one with a specially built chassis by Chassis Services of Leighton Buzzard. The later chassis (and I am not sure where yours comes) had the chassis set further back on the standard LWB chassis, then the extention is added at the back. If that's the case with yours, it should be easy to get the extention plates and retro fit them. The key thing is is where your rear axle is. Is it at the very back of the chassis, or is there some chassis behind it?
FredTransit
Mk2 Trannyist
chassis length
Postby john leeman » Sun Jan 22, 2006 10:43 pm
what I ment to say was NOT more than 1/2 your wheelbase after your back axle on commercial vehicles
john leeman
Re: chassis length
Postby Luke » Sun Jan 22, 2006 10:45 pm
john leeman wrote:what I ment to say was NOT more than 1/2 your wheelbase after your back axle on commercial vehicles
oh i see :lol:
STRETCH
Postby vanmania » Mon Jan 23, 2006 2:01 pm
hI MIKE
ITS NOT REALY EASY IVE DONE 1 BEFORE I STARTED CUTTING BEHIND THE CAB ABOUT 8INCH HANGING THEN PUT NTERNAL PEASE IN, 18 TO 20 INCH INTO THE CHASSIS AT THE CAB THEN YOU SLEEVE IT SAME AGAIN WHEN YOU JOIN THEM THEN YOU GOT TO REMEMBER TO EXTEND THE PROPSHAFT & HANDBRAKE CABLE& BRAKE PIPES. I CANT EXPLAIN IT ALL ON COMPUTER ITS TOO TECHNICAL
vanmania
Postby mike730 » Tue Jan 24, 2006 6:32 pm
I,m going to cut it about 8" behind cab and sleeve the chassis internally using 50mm x 100mm box top and bottom ,then i'm going to plate up the outside of the chassis.Handbrake,brake line & exhaust easy to sort,propshaft will be a bit harder to do but got a few props to try.Just put the tranny in the garage,should have it cut in half soon.
mike730
