does anyone know which is the speed pulse sensor wire for fitting SAT NAV
ta
gregw_aus wrote:I've just been through this while ordering a cruise control for my Vj 2004 transit with Auto (ASM?) gearbox.
I was told to connect to the wire that goes to speed but I had a lot of trouble pulling the dash apart and looking at the plug that connects the back of the instrument panel, it would have been very difficult finding the right wire anyway.
If you have a VJ transit with Auto gearbox, the simple way is to find the blue and white stripe wire at the sensor on the gearbox. Mine was a the back of the gearbox on the left hand side. Measure from there to ground.
It took me a while to find a multimeter with a frequency scale until I found that most recent model cheap meters as well as better quality Fluke meters have this. If you look at the AC scale on a Fluke meter and there's a yellow Hz next to it, you press the yellow button to change from Volts to frequency in Khz.
I ran a wire through the firewall and behind the engine to the speed sensor. If you drive at 50 kph, the frequency reading on the meter should be fairly stable.
Cheers,
Greg.
