Muddy Trucker wrote:Some ringers have the new number welded over the top and then have the plastic optional trim fitted to cover the welding leaving just a small window to read the chassis number .
gemini wrote:drivers side step, lwb sht, the year should be stamped inside on the roof rail corners
heraldcoupe wrote:Do you mean on the inside at the back?
doughythevanman wrote:A VIC is only necessary when it's been writ off or cat c damaged.
transitgeoff wrote:strange because Transits dont need a vic check, simple as that, vic is for cars only
