CAUTION:
Diesel fuel injection equipment is manufactured to very precise tolerances and fine clearances. It is therefore essential that absolute cleanliness is observed when working with these components. Always fit blanking plugs to any open orifices or lines.
Note:
As well as carrying out its normal function the glow plug indicator also acts as an engine check lamp which will flash continuously when a hard diagnostic trouble code (DTC) is detected by the powertrain control module (PCM). Soft DTCs are also stored by the PCM but will only be known if the system is checked for DTCs using WDS.
Note:
If a DTC is detected, all DTCs must be cleared after the concern is repaired. Failure to clear all DTCs may cause driveability concerns.
Note:
If the fuel level in the fuel tank drops below approximately four litres, rough running will occur. This is to signal to the driver that the vehicle requires refuelling in order to prevent the fuel system from running dry.
1. Verify the customer concern.
2. Visually inspect for obvious signs of mechanical or electrical damage.
Visual Inspection Chart
ÚÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÂÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄ¿
³ Mechanical ³ Electrical ³
ÃÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÅÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄ´
³ Fuel leak(s) ³ Fuse(s) ³
³ Fuel filter ³ Relay(s) ³
³ Air cleaner element ³ Wiring harness ³
³ Vacuum line(s)/vacuum ³ Electrical connector(s) ³
³ connections ³ ³
³ Hose(s)/hose connections ³ Passive anti-theft system ³
³ ³ (PATS) LED operation ³
³ Tube(s)/tube connections ³ Sensor(s) ³
³ Contaminated fuel ³ Glow plug indicator ³
³ Fuel supply line(s) ³ Powertrain control module ³
³ ³ (PCM) ³
³ Fuel return line(s) ³ ³
³ High-pressure fuel supply ³ ³
³ line(s) ³ ³
³ Fuel injectors ³ ³
³ Fuel injection supply ³ ³
³ manifold ³ ³
³ Fuel pump ³ ³
ÀÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÁÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÙ
3. If an obvious cause for an observed or reported concern is found, correct the cause (if possible) before proceeding to the next step.
4. If the cause is not visually evident, verify the symptom and refer to WDS to retrieve the diagnostic trouble codes (DTCs).
5. If no DTCs related to the concern are retrieved, proceed to the Symptom Chart below to continue diagnostics.
Symptom Chart
Condition(s):
o Engine does not crank and glow plug indicator is flashing
o Engine cranks but does not start and glow plug indicator is flashing
o Poor starting and glow plug indicator is flashing
o Poor starting
o Engine starts but immediately stops and glow plug indicator is flashing
o Poor idling and glow plug indicator is flashing
o Poor idling
o Engine stumbling and glow plug indicator is flashing
o Engine stumbling
o Engine lacks power and glow plug indicator is flashing
o Black smoke at idle and glow plug indicator is flashing
o Excessive black smoke during acceleration and glow plug indicator is flashing
o Black smoke at cruising speeds and glow plug indicator is flashing
o Blue smoke and glow plug indicator is flashing
o Blue smoke
o White smoke and glow plug indicator is flashing
o White smoke
o Engine misfire and glow plug indicator is flashing
o Engine misfire
o Engine knock at idle and glow plug indicator is flashing
o Engine knock during acceleration and glow plug indicator is flashing
o Excessive fuel consumption and glow plug indicator is flashing
o Engine cuts out during hard acceleration
