Later wedge wiring
Later wedge wiring
Postby bortaf » Thu Jan 26, 2006 8:07 pm
Tot the engine in but the cold start is a leccy one not the wax stat and cable like the old one, anyone know if it's just a 12V feed (lost me meter) if it is i'll just put a switch in as a choke :D
Got to change the water temp sender and the alternator, appart from that all the same except this engine has a lift pump behind the Ex manifold so some ne pipe and a few jubalee clips and should be done tomorrow. :D
Current fleet
Mk7 transit ambulance
Mk1 Mondeo 1.8 STD
Mk5 fiesta 1.25
Mk6 fiesta 1.4TDCi
bortaf
Postby Nighthawk » Thu Jan 26, 2006 9:10 pm
The cold fast idle I think your talking about did use a 12v supply, the power went to the waxstat on the bosch pump via a sender on the engine block near the fuel filter, the earth point for the system is below the pump onto the engine block...from memory the 2 terminal temp sensor also used the same earth point.
Nighthawk
Postby bortaf » Sat Jan 28, 2006 12:08 am
cheers i've changed the water temp for the old one (or will when i put it back in :)
Can i use the fast idle in me old van? or is the switch an easyer route the sender is there on the block and theres wires in me old loom for it but no wres to earth on the block (if that makes any sense?)
Current fleet
Mk1 Mondeo 1.8 STD
Mk5 fiesta 1.25
Mk6 fiesta 1.4TDCi
bortaf
Postby Nighthawk » Sat Jan 28, 2006 12:31 am
You could easily make the electronic cold fast idle work on the old van, give it a fused ignition fed supply to the switch by the sender, from there you need a feed out of the sender to the waxstat on the pump.
You'll need to tag on an earth cable from the pump backet to the block too from memory.
Nighthawk
Postby bortaf » Sun Jan 29, 2006 1:08 am
All running :D
Had a bit of a panic when loads of oil appeard over the alt after a few mins running :o then i noticed i'd knocked the dipstick out a bit and it was flying out of there :lol:
Gave the new engine and box a good look over, recon engine 10/05/05, new clutch, new rad, new fan blades all new hoses and recon fuel pump and starter motor at the same time, possably gearbox as well, it's very very clean and sweet as a nut with new mounts as well.
Steering colums swapped and door locks, seats next then the radio cassette :D
Best £200 i ever spent :lol:
see how the fast idle thing goes it started and ran perfect today without it.
Current fleet
Mk1 Mondeo 1.8 STD
Mk5 fiesta 1.25
Mk6 fiesta 1.4TDCi
bortaf
