Automatic gearboxes
Automatic gearboxes
Postby the gardener » Fri Mar 14, 2008 5:21 pm
Can't drive till Easter weekend or work till end of April following an op... when we left the van at Christmas for two weeks the battery flattened, so I managed to talk Mrs G into driving the Yokohama Bullet 2 (2.4 Toyota Camry auto) last week before I went in, she hasn't driven for two years, and yesterday I managed to start the van and get her to take it for a run. Those dual passenger seats are uncomfortable, you can't sit with your legs straight out, but we do have three people in regularly so it stays. To cap it all Mrs G says the brakes are better than YB2 which has just had new discs and pads on the rear and only done 6k on the 'new' fronts. Can you get an auto box on a transit? I'm lazy and like what I call 'point and shoot'.
the gardener
Re: Automatic gearboxes
Postby FredTransit » Fri Mar 14, 2008 5:31 pm
Talk to AndyG! He will fill you in :wink: .
FredTransit
Mk2 Trannyist
Postby AndyG » Sat Mar 15, 2008 1:08 am
Says it all really :!: :lol:
And that was back in the old MK1 days :!: :o
A proper auto box was an option until the MK6 came out :!:
We had a 3 speed automatic until about 1988 when we changed over to a 4 speed box :!: (overdrive)
When the Smiley was launched in 1994, the UK only ever saw a diesel auto :|
If you wanted a smiley auto Transit, you had to also take the 85PS Turbo diesel engine and twin batteries :!:
There was no other engine option available :!:
The extra £1,500.00 + vat made it a rare option :!: :o :lol:
In 1997/8 we also saw the launch of the "autoclutch" with the 76PS engine :!:
It was basically a manual van with no clutch pedal :!:
When the MK6 came out in 2000, you had to wait at least a year before seeing the infamous "durashift" :!:
This was also known as the "ASM" (auto shifting manual) Now this had auto change or paddle shift (on steering wheel) manual box :!:
Unfortunately it never even came close to driving like an automatic and proved extremely unreliable :!: :roll:
To the point that they never made it available on the MK7 :!:
If you are going to buy a second hand proper auto, check that the gear changes are smooth (unless on kickdown :!: :shock: :lol: )and no revving up between changes :!:
Check that reverse works when hot and that the overdrive isn't slipping :!:
Check the colour and odour of the transmission oil :!: It should be a nice cherry red and not a burnt out brown colour :!:
Personally, given the choice, I wouldn't have a manual ever again, for what and where I use my van :!: (In and around London)
Postby madmark » Sat Mar 15, 2008 11:49 am
8) 8) well done andyg :wink:
Postby the gardener » Sat Mar 15, 2008 3:14 pm
Thanks AndyG for that comprehensive history, why aren't autoboxes more available on vans, is it gearing, build cost, maintenance / reliability, public acceptance or other issues? I'm on my second auto in a 2.0+ engined car but a lot of my customers have them in small cars now - Honda Civic & Jazz, Nissan Micra, Corsa. I'm off to look at a 2.5V6 Mondeo estate if I can drive next weekend which is 6speed manual which surprised me in that spec.
the gardener
Postby Daveyboy » Sat Mar 15, 2008 3:43 pm
My mate bought a first generation ex police sprinter 412 which was an automatic.
Daveyboy
Postby AndyG » Sat Mar 15, 2008 5:32 pm
the gardener wrote:Thanks AndyG for that comprehensive history, why aren't autoboxes more available on vans, is it gearing, build cost, maintenance / reliability, public acceptance or other issues?
Well, generally speaking, people always like to "save" money and autoboxes are usually an extra cost option :!:
There are also a lot of narrow minded people with "funny" ideas :!: :roll: :lol:
When auto boxes started life, they were quite primitive although quite a clever idea :!:
The design was such, that they did sap a noticeable amount of power and therefore did use more fuel :!:
As a result, they weren't generally offered on small engined/low output cars :!:
We have come a very long way with autoboxes :!: so much so that BMC started offering auto on really small cars like the Mini and 1100/1300 range :!: :D
To compensate for the very small output of these engines, they all had 4 speed boxes (not overdrive)
They proved quite popular and a lot of the "posh" Vanden Plas' left the showrooms with auto :!:
The other problem that the autoboxes reputation suffered, was when they did give trouble, most so called mechanics would suck there teeth and recommend a complete and expensive (and usually not required) compete rebuild :!: :roll:
So the owner would have to decide, either get it repaired, or sell it while it still goes :!:
Now, this is the next stage of their reputation suffering :!:
The new owner buys this faulty auto (not having a clue how they work or what signs to look out for) and soon discovers has a problem :!:
Off he goes to his so called mechanic, which bodges it up and of course the owner starts the "autos are no good" syndrome :!: :lol: :lol: :lol:
The Transit auto boxes also kept evolving :!: :D
We had the 3 speed unit which was upgraded to a 4 speed overdrive with "lock up" torque converter for even greater fuel efficiency and even more relaxed motorway cruising :!:
The overdrive ratio being slightly higher than that of the manual Transit :!: :o
They never stopped there either :!:
In their search for more efficiency, they went over to the partially electronically controlled version that adjusted the pressure rail of the oil pump so that the box wasn't at "full pressure" all of the time, as this was considered a waste of energy and a further saving to fuel/power can be made :!:
Unfortunately this mod. did lead to the overdrive band burning out (lack of pressure) on some of these boxes (including mine :roll: ) and most would be out of warranty by then :!: :roll:
Ford did release a mod for this and it's so simple to do, as it doesn't involve the box being removed :!: :wink:
Heat generation is the number one killer of auto boxes :!: :(
And I am looking into additional cooling for mine :D
One more thing :!: Some people think that autoboxes are just that :!: And for that reason automatically never need attention :!: :roll:
Oils have improved over the years, but they would still benefit from an oil and filter change say 40 to 60 thousand mile intervals :!:
Autoboxes have a lot of advantages over a manual box, not least the work load taken off the driver :!:
If I was doing a lot of motorway driving, then this wouldn't really be an issue :!: :D
Postby rover » Sat Mar 15, 2008 7:03 pm
With all that typing I reckon you could do with an automatic computer :lol:
Cooling is definately the key, my box has started giving me trouble (after a trip to Brum last week) with overheating, I have now put a small oil cooler on and ordered a larger one, when I took the pipes off the integrated cooler (cools through the rad) the oil only trickled out and the flow and return pipes were almost cold, I dont think there was much flow through it at all, and that was after an hours running! So if you get a fairly high mileage one I would suggest either renewing the rad or fitting an external cooler :!:
Rover.
rover
Postby AndyG » Sat Mar 15, 2008 7:23 pm
Can't the blockage be blown out :?:
And yes, you are right :!: A nice voice activated commy would be 8) 8) 8) :lol: :lol: :wink:
They have some really nice parts for autos in the States :!: And not too expensive either :!: :!:
They do deep sumps to increase the amount of oil, finned sumps made of ally, to aid heat dissipation, external magnetised oil filters, and thermostatically controlled fan assisted radiators that can be mounted anywhere :!: :o 8) 8) 8) :D :D :D
Postby rover » Sat Mar 15, 2008 8:56 pm
It may be possible, but considering the rad may be 18 years old (dont know the previous history) the chances of damaging it and cause mixing of fluids is highly likely :!:
The safer option is a standard rad and external oil cooler, or a new rad, but at £125+VAT for a rad or £40 for a cooler and refit my perfectly good standard rad its not really a contest at all :D
Re the parts from the States, I have recently enquired about a fully recon'd torque converter, total price including delivery would be around £100, and thats a heavy duty unit and you can specify the stall speed you want 8)
Rover.
rover
Postby Neil » Sat Mar 15, 2008 9:46 pm
my mk 2 s auto,same box 25 years thats because its always been serviced ,people just never assume to service the autobox until its too late
Neil v6
Neil
Postby 100 T280 » Sun Mar 16, 2008 9:53 am
Andyg wrote:and no revving up between changes :!:
What causes that then? The '85 Granada Scorpio I've got did / does that, on a light throtle between 1st and 2nd, revs its nuts off, loses drive, then drops into gear :? (although it's not been driven for about 4 years, or started :oops:)
'02 100 T280 SWB Exec. FWD Medium Roof 2.0 DuraTorq TDdi 100ps
College Blue, Alloys, Eberspächer, Twin Batteries, Single Seat,
"Park Distance Control", AirCon, Rev. Counter, 7000RDS.......
100 T280
Postby 24vtranny » Sun Mar 16, 2008 10:41 am
nearly all new gen,and smily faces here in aus are auto, desial turbo and non turbo, :lol:
24vtranny
Postby rover » Sun Mar 16, 2008 12:04 pm
If it only does it between 1st and 2nd then the chances are the bands are out of adjustment..
Is it a C3 or an A4ld?
Band adjustment is pretty straight forward :D
Rover.
rover
Postby 100 T280 » Sun Mar 16, 2008 1:09 pm
rover wrote:If it only does it between 1st and 2nd then the chances are the bands are out of adjustment..
The first of the A4LDs 8) I had a go at adjusting the (Brake :?: ) Bands, made some difference, but not a lot.
100 T280
Return to Transit Talk
