pros + cons lwb swb?
Postby sean37 » Sat Mar 22, 2008 9:54 am
what are the pro`s and cons of a lwb and swb mk1 van if any? :D any one help me thankyou sean :)
sean37
Re: pros + cons lwb swb?
Postby madmark » Sat Mar 22, 2008 8:37 pm
sean the lwb is a difrent motor all together its heavey duty so it doesnt drive as good unless its loaded ,mine is ok but a swb would drive nicer! :wink:
Postby sean37 » Sat Mar 22, 2008 10:11 pm
cheers mark is their some where i can go to read up on lwb rather than keep annoying your self :?: :) you say yours is okay is that due to it being modified or something you get use too cheers buddy
sean37
Postby madmark » Sun Mar 23, 2008 1:36 pm
mate your allways welcome to ask :wink: mine has had so much done to it ,its got a difrent axle ,and gearbox and a pinto 2ltr at the moement! and disc front brakes as well!
it goes ok on the flat but doesnt like hills! :lol: :lol: :lol: :lol:
Postby sean37 » Sun Mar 23, 2008 10:10 pm
cheers mark if or when i get my project i will be asking you quite a few questions :D you say 2Lpinto at moment are you thinking of changing engine what was standard engine :?: :D
sean37
Postby FredTransit » Mon Mar 24, 2008 9:01 pm
I haven't driven a LWB Mk1 in over twenty years, but the MK2 SWB and LWB are different to drive. I find the LWB is a nicer drive (Mk2), more steady due to the longer wheelbase and two extra rear wheels. As far as the Mk1 goes, the disc front axle swap is very easy (you may need to do the servo to match on the earlier vans), and the WB and the LWB did come with the same engines, originally 1600 crossflow and 2L V4 petrol engines, and Perkins diesel, our SWB has a 2L V4 and the Perkins is often replaced with the Di.
FredTransit
Mk2 Trannyist
Postby transitgeoff » Mon Mar 24, 2008 9:05 pm
hmmm :?
transitgeoff
Postby Neil » Mon Mar 24, 2008 9:09 pm
very hmmmm :wink:
Neil v6
Neil
Postby sean37 » Mon Mar 24, 2008 9:57 pm
cheers fred very informative :D i must admit i prefer the look of the lwb and the added carring ability allthough if people think its better to have or start with a swb than i would do that. Providing i can find a cheep mk1 that is. Searching mk1 sean :D :D :D
sean37
Postby FredTransit » Mon Mar 24, 2008 10:28 pm
For some odd reason some people think that a SWB takes up far less room :lol: ! Obviously they have 2 more tyres to buy, other than that the wheel arches make them wider and the roof line is higher. My first van was a Mk1 SWB so I have a soft spot for them! On the Mk2s I defo prefer to drive the LWB.
FredTransit
Mk2 Trannyist
Postby Ollie » Tue Mar 25, 2008 7:58 pm
For what its worth I prefer lwb too, mainly as they seem to sway less and feel a lot safer for towing, but I'd also like the feel of being able to get it in tha garage without removing wheels and flattening tyres! for that matter most people don't really get the luxury of choice, you get whichever van finds you!! , with more SWB seeming to survive , i guess because they can be dry stored easier and wheren't all bought to be overloaded and battered in quite the same way :lol: :lol:
Ollie
Ollie
Postby sean37 » Tue Mar 25, 2008 9:07 pm
makes sense ollie :D though i couldnt get a swb let alone a lwb in my shed :) unless i turn shed into mk1 if you get my drift but youre right on the score regarding what turns up hreres hoping it does thanks for the post :D :D
sean37
Return to Mk 1 & 2
