fuel pressures
fuel pressures
Postby Turbo Tim » Fri Apr 04, 2008 10:08 pm
Van still running bad, just wondering if any one has any idea what fuel pressure should be on inlet to injection pump, need to see if pump in tank is working correctly an if any fuses or relays are about , looked on TIS but it doesn't say anything about any of that, any thoughts , Regards Tim
Turbo Tim
Re: fuel pressures
Postby coconut » Fri Apr 04, 2008 10:38 pm
It hasnt got a pump in the tank, it works by suction :!:
coconut
Ford Technician
Re: fuel pressures
Postby Turbo Tim » Sat Apr 05, 2008 9:10 am
I spoke to ford in Horsham a they say there is a pump / sender unit in tank. On older style deisel's a rotory pump needed about 3 to 5 psi and the inline pumps needed 20 to 30 psi, i thought all deisels had to be pressure fed,regards Tim
Turbo Tim
Re: fuel pressures
Postby Guy88 » Sat Apr 05, 2008 9:17 am
is it a TDDi or TDCi
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Re: fuel pressures
Postby Turbo Tim » Sat Apr 05, 2008 9:19 am
tddi
Turbo Tim
