Sound insulation/deadening / Silence of the Di ! Is it poss?
Postby AndyG » Sun Apr 27, 2008 11:47 pm
Well there's only two things that people moan about a MK5 Transit :!: :roll: :roll:
Rusty front wheel arches :!: (now cured :D )
viewtopic.php?f=27&t=26443
And the noise of the Di engine/injection pump :!: :x :x :x
And boy is mine one of the noisiest there is :!: :shock: :shock: (ask Guy88 who can confirm and has compared)
Well I've had enough :!:
What made my mind up about doing something about it, was when I had a ride in my old 1996 van :!: Oooooooh :!: Sooooooo quiet :!: :shock: :shock:
Having spoken to various people about sound proofing, the word Dynamat (xtreme) kept on popping up :!:
So guess what................
Dynamat xtreme was purchased and the attack has started :!: :D
In fact, it started last year with the ceiling above the driver :!:
I'm going through this sound deadening and making notes as I go along and will tell you all what parts of the van make a noticeable difference :!: :wink:
Firstly the purchases :D
Here's a sheet of Dynamat against one of my wheels, so you get an idea of how large they are :D
With the A pillar trims sunvisors and courtesy lamp removed, it was an easy job getting the roof lining out of the cab area :!:
Three sheets later, the ceiling is virtually completely covered :!: :o The small bits trimmed off weren't wasted either :!:
They went in the edges :!: :wink:
For this stuff to be effective, it must be pressed firmly into the grooves :!: :D
That's the hail stones, rain and the howling ladders quietened down :!: :D :D
Re: Sound insulation/deadening / Silence of the Di ! Is it poss?
Postby magpie » Sun Apr 27, 2008 11:56 pm
Forgive the comment but is it not simallar to "KINGSPAN" insulation were you might get more product fer less money.
magpie
magpie
Postby MrMPuk » Sun Apr 27, 2008 11:57 pm
magpie wrote:Forgive the comment but is it not simallar to "KINGSPAN" insulation were you might get more product fer less money.
magpie
Nothing like it.
Postby AndyG » Sun Apr 27, 2008 11:59 pm
magpie
Not to be rude, but I've never heard of them :o
I've also tried a recommended alternative, as you'll see a bit later :!: :)
Postby AndyG » Mon Apr 28, 2008 12:00 am
Next bit down from the top is the dash :!:
The air intakes at the front, underneath the windscreen look like a good candidate for noise amplification :x
So wipers off, black scuttle trim removed, and a good dose of Dynashield sound deadening spray :!: :D
And the other one :!: :lol:
Postby AndyG » Mon Apr 28, 2008 12:08 am
Well I certainly wasn't looking forward to this bit :(
But comparing the underside of my dash to others (older ones), mine didn't seem to have any sound absorbing at all :!: :o :(
So the dashboard is taken apart :!:
Switches all out :!:
And replugged on the other side of the dash to keep them all in order :D
Postby AndyG » Mon Apr 28, 2008 12:12 am
Unlike earlier dashboards, these late ones come out with the reinforcement tube :!:
There's also a very well hidden 10mm bolt that I've marked for you, in case you ever need to remove a late smiley dash :D
Postby AndyG » Mon Apr 28, 2008 12:18 am
:shock: O M G :shock:
There's a couple of wires there :!: :lol: :lol: :lol:
It's a good idea taking photos, as you can see where all the cable clips go for reference :!: :wink:
Postby AlanN » Mon Apr 28, 2008 12:23 am
No
you can't stop there
More
Postby AndyG » Mon Apr 28, 2008 12:28 am
There's a reinforcing chassis like box section just below the windscreen that looks like a good noise amplifier :roll: :roll:
So this was sprayed internally with the Dynasheild spray :!: :D
Next plan was to Dynamat the bulkhead/firewall :!:
Starting from the top (below the windscreen) the Dynamat was cut into smaller sections, so it would fit in a lot easier :!: :D
With the backing still on, it allows you to first mould it into the shape you want :D This makes it a hell of a lot easier to fit into difficult places once the backing is removed and it's all sticky :!: :!:
Postby madmark » Mon Apr 28, 2008 12:37 am
:shock: andy it is very strange you have a noisey epic ,i jave allways found them to be much quiter than standard di engines! :? :? :? :?
Postby AndyG » Mon Apr 28, 2008 12:40 am
Ford's idea of sound/heat insulation :roll:
My idea of sound insulation :!: :lol:
Phew :!:
That's the top done to almost the floor :!: :roll:
This certainly wasn't a nice job :!: But at least that bits done now :!:
Clips and wiring back :!: :D
Postby AndyG » Mon Apr 28, 2008 12:43 am
madmark wrote::shock: andy it is very strange you have a noisey epic ,i jave allways found them to be much quiter than standard di engines! :? :? :? :?
What year was your latest one then Mark :?:
Is it to do with the "later fueling" to make them Euro 3 :?:
Postby madmark » Mon Apr 28, 2008 12:45 am
are uero 3 cheaper tax for you then! :lol: :lol:
my last was a r reg but my auto on a 1999 was as quite as a mouse! :wink:
Postby AndyG » Mon Apr 28, 2008 12:48 am
madmark wrote:are uero 3 cheaper tax for you then! :lol: :lol:
:lol: Cheaper tax :roll: :roll: :lol:
Did you have your 1999 one from new :?:
Did it have it's original EPIC pump :?:
