fishman wrote:hi have you done the valve stem seals if worn oil gets in inlets
thrud wrote:i moved the fuel return from no.4 to no.1,
how tight should the fuel filter be? it located ok and with the collar tight i can still rotate the filter![]()
also the 'banana's' were lined with oily slime, from butterfly to valves, i clean them as best i could but coulden't get it all out
please don't say that MrMPuk
thrud wrote:would this cure my probs guys??
http://cgi.ebay.co.uk/2-5Di-Ford-Transi ... dZViewItem
Users browsing this forum: savi18
