Mk3 new wings and front refurbishment
Postby scooter » Wed May 21, 2008 12:32 am
Hi folks here goes ,first i would like to say that i have learnt a lot being a member of this forum.
I needed to fit new wings as i was fed up patching the old ones up,and found an article here on how to do it as it was something i had never done.
I bought to wings and a small air compressor and spray gun 3cfm,no your talking novice here but i was determined to have a go.
I sprayed the wings in my garden shed using a heat gun to give the panels some heat between coats as it was Febuary plenty primer inside and out first.
In March i started cutting off the old wings with an angle grinder and spot weld drill,i was a bit nervious as this was all new to me,anyway the wings came off i did one side at a time.
The inner wings were a bit rotten as i was told to expect so i used the rottary wire brush on a drill to clean them up ,which left a few holes mostly in the middle which i then fibreglassed back into good shape letting the first coat of resin go almost hard so the fibre would stick nicely in place.
right i cant weld tried it once not my thing ,so i had painted wings how the hell am i going to do this ,well i did what i knew bolted them stickaflex to hold wing down door seem ,then when both were on run it to a local shop for a few spot welds.
what do you think guys they seem solid.
Now that i feel like a dab hand with the spray gun lol i seen some pics here of vans with mesh on the smiley grills so i had to do it,sprayed the front bumper in the shed and fitted mesh in the grill.
The work was carried out including spraying the back and sides outside my door in the main street,my neighbours looking out their windows people who dont like to be seen washing their cars, i dont really care.
anyway heres pics of my pride and joy.
scooter
Re: Mk3 new wings and front refurbishment
Postby scooter » Wed May 21, 2008 12:40 am
Oh by the way i have tried to get pinstripe to put back on the wings,they dont seem to make it anymore i tried everywhere
it just looks a bit odd where it stops on the doors.
scooter
Postby AndyG » Wed May 21, 2008 12:41 am
Looks more like a MK5 to me :!: :wink:
Good work :!: 8)
Postby scooter » Wed May 21, 2008 12:47 am
Andyg wrote:Looks more like a MK5 to me :!: :wink:
Good work :!: 8)
That proves iam a novice lol
scooter
Postby AndyG » Wed May 21, 2008 12:56 am
:lol:
Postby Ucof » Wed May 21, 2008 8:43 am
WoW :D
The inside of the camper looks amazing! LWB High tops are the way forwards! :D
Keep up the great work!
1991 MK3 SWB Low Roof 120 2.0Ltr Pinto (not for much longer :( )
Scientists have proven that the awesomeness of a forum thread is directly proportional to the number of pictures it contains.
Ucof
Powered by Nutella
Postby Ford Sprung Van Tastik!! » Wed May 21, 2008 8:47 am
Good work :!: 8)
Yes deffo a MK5 :)
Nice job.
Can't you get some striping tape from a Motorists Discount Store :?:
Rare genuine Mk5 190 LWB 115ps Turbo Diesel Intercooled .
If you can't fix it... use a BIGGER hammer !!!
Postby scooter » Wed May 21, 2008 1:10 pm
Good work :!: 8)
Yes deffo a MK5 :)
Nice job.
There must be somewhere that has old stock ,problem is cars dont have pinstripe anymore and it seems they stopped making it a couple of years ago.perhaps ebay,or lining tape and sray it on although i dont fancy trying that.
I'll just keep looking :lol:
scooter
Postby AlanN » Thu May 22, 2008 4:49 pm
Those pin stripe lines are cut on a lathe, my firm used cut them, but we dont do vinyl stuff any more, only masking tape and pvc. It maybe easier to get a new roll from ebay.
Postby bigmastif » Thu May 22, 2008 6:11 pm
is it not the white stripe he is looking for :?:
any signwriter will have it will be vinyl :?
bigmastif
Postby AlanN » Thu May 22, 2008 8:15 pm
bigmastif wrote:is it not the white stripe he is looking for :?:
No, he wants the pin stripe above it :!: but the original will have aged and new will show up
Postby scooter » Mon May 26, 2008 5:11 pm
As it is you dont really notice the wings dont have it,yes i see your point new pin would be really bright but then finished i suppose,I'll have a look on Ebay thanks gents.
scooter
Postby AlanN » Mon May 26, 2008 8:42 pm
Personally, I'd do away with them
Postby scooter » Tue Jun 03, 2008 7:10 pm
AlanN wrote:Personally, I'd do away with them
Iam thinking about doing just that
scooter
Postby AlanN » Tue Jun 03, 2008 7:25 pm
Its a tidy looking van and doesnt need fussy bits on it, black up the tyres, clear indicator & repeater lenses to match the white... 8) I like the white mesh.
Sorry to sound so opinionated :oops:
