waerhy wrote:captain hook wrote:Another £14 down the toilet.........intransit89 wrote:just got these for when i go twin![]()
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... :IT&ih=025
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... :IT&ih=001
just need a petrol battery tray and a 2nd battery now![]()
is it really up to you what other people spend there money on? alot of negativity towards this lad. bit unnecessary i think.
you are doing a grand job int. keep it up look forward to the progress reports
MrMPuk wrote:To be fair the Captain is right on this one, how are those, 2 totally unmatched leads going to connect a battery up?
intransit89 wrote:MrMPuk wrote:To be fair the Captain is right on this one, how are those, 2 totally unmatched leads going to connect a battery up?
easy![]()
MrMPuk wrote:intransit89 wrote:MrMPuk wrote:To be fair the Captain is right on this one, how are those, 2 totally unmatched leads going to connect a battery up?
easy![]()
So why not just make your own and save some money!
transit killer wrote:Those leads should do the job fine Rob
Red Between the two + terminals Black down to ground , not brain surgery.
MrMPuk wrote:But the negative lead has a battery terminal clamp on one end and a ring terminal on the other and the positive lead has a ring terminal on both ends.
intransit89 wrote:MrMPuk wrote:But the negative lead has a battery terminal clamp on one end and a ring terminal on the other and the positive lead has a ring terminal on both ends.
should still be ok thoi imagine
Gurj51ngh wrote:you imagine to much that may be the problem......................
slow transit wrote:intransit89 wrote:MrMPuk wrote:But the negative lead has a battery terminal clamp on one end and a ring terminal on the other and the positive lead has a ring terminal on both ends.
Blu-tac![]()
