Extending Van to accommodate two rear diffs
Re: Extending Van to accommodate two rear diffs
Postby bazw » Wed May 28, 2008 5:52 pm
brain has gone , reading to many threads at one time parts of last 2 posts should be in with the "jag V12 in a tranny thread "
but fitting info is good
think i need to come out of the site now LOL
350L Series 56 plate
2.4 duratorq 115 ps
A.R. 4.27
bazw
Postby AlanN » Wed May 28, 2008 6:06 pm
I look forward to this one 8) , mind you Id also love to see something like a MK5 done :lol:
Postby Luke » Wed May 28, 2008 7:00 pm
jaimo693 - what engine do you intend to fit in this as baz has a good point about the axles ratios - you dont want to go to the hassle of doing the conversion only to find you cant get a suitable ratio for the axle you have chosen :idea: :D
Postby jaimo693 » Wed May 28, 2008 7:20 pm
Hi Luke:
Probably going with a V6. But in contact with a garage called Burnham Autos at the moment and talking about V8. Prefer to do the V6 as I know these back to front and also have the engine mounts from an MK11 Ambulance which will sit the motor nice and low which is good for the cornering. I also have an LSD diff from the ambulance and the ratios have already been changed, but its not as good as a Jag axle :)
I had a Bedford CF1 years ago with a Jag axle and V8 and the ride quality and handling is much better. Not only that, but when travelling in Europe on the motorways, having a twin wheeler you get charged double at the tolls!! :shock: So having the Jag axle with one FAT wheel instead of two seams good and can do much more with getting nice wheels.
Leaning towards Jag axles at the moment, just got to find some :D Not sure on Engine, V6 if poss.
James
Transit Mk111 LWB 1987 - Transit Mk1 LWB 1977 - CB Handle: Switch
Chrome Restoration - Chrome Plating & Custom Van Shop
jaimo693
Postby Terry » Thu May 29, 2008 4:43 am
HI
The Range Rover conversions were PROBABLY done (originally)to make them useable as fire tenders.
So try a fire engine maker/builder...Chubb used to do builds but I don't know if they still do.
Go to your local small airfield they probably have a 6 wheel RR, the idea obviously was they can carry the extra weight (of water) & go cross country to get to the burning whatever.
H.T.H.
Terry
Pallet Puller
Terry
Postby 93fxdl » Thu May 29, 2008 4:26 pm
this may seem stupid but what about using indespension type units for the second axle or a beam trailer axle you can get them made to any width you want the only thing is the pcd so you will probably have to use spacer adaptors or possibly redrill as for using a jag axle they were very popular in the 70s for street rods so try investigating a few rod sites
ps i once saw a three axle landrover with a sodding great recoiless gun mounted on it down at southampton docks
ttfn glenn
93fxdl
Postby Luke » Thu May 29, 2008 7:28 pm
93fxdl wrote:this may seem stupid but what about using indespension type units for the second axle or a beam trailer axle
like an ALKO chassis use on fwd campervans :idea:
Postby FredTransit » Fri May 30, 2008 12:54 am
I've got a Mk2 LWB transit, but can't get into photobucket at the moment. I did post a pic of it, it was way back in member's vans.
FredTransit
Mk2 Trannyist
Postby FredTransit » Fri May 30, 2008 1:13 am
Here you go, it's stretched but has only one rear axle.
FredTransit
Mk2 Trannyist
Postby MR BigBeefy LDV Guru » Fri May 30, 2008 1:29 am
i may be wrong but isnt madvanmans 3001 a twin axle ?????
Transit dreamer!
Postby 93fxdl » Fri May 30, 2008 8:50 am
many many moons ago there was a custom artic built with twin rear axles and also i once saw a tipper with twin axles but this was a working builders truck but unfortunately dont have any more info other than i saw it parked on the side of the road in dorset
ttfn glenn
93fxdl
Postby Luke » Fri May 30, 2008 12:25 pm
MR BigBeefy LDV Guru wrote:i may be wrong but isnt madvanmans 3001 a twin axle ?????
yes it is but it's not stretched :D
Postby Luke » Fri May 30, 2008 12:26 pm
93fxdl wrote:many many moons ago there was a custom artic built with twin rear axles
there still is :D sixwheelphil on here has one 8) - there are some pics on here - i'll post emin this thread if i can find em :D
Postby jaimo693 » Fri May 30, 2008 7:59 pm
Very nice Van FredTransit!
Ok, so it looks as though its going to be another transit axle! Move the leafs springs apart or inwards on one of the axles. Cut the back end of another transit and attach it behind the existing arch so it will look like this :)
Anyone see any further problems with doing it this way? ......Ok, who wants to give me a hand then :lol:
jaimo693
Postby slow transit » Fri May 30, 2008 8:42 pm
FredTransit wrote:Image
Very smart Fred how much longer is it :?:
Did you extend it yourselfs :?:
Looks well cool 8) 8) :lol:
slow transit
