mrtaximan wrote:hi lads thanks for your help.As the car is under warrenty until 100,000mls my son has sent the car to dagenham motors epsom on a flatbed.they are going to have a look and see if they can do anything today as the car is off the road.Just found this out from a ford mechanic-ford tdci engines water pumps do have an issue with impellors falling off on the inside/pully bolts shearing off on the pully outside!!! maybe on the right track.Also i will get a photo of the car on the sight asap.ps. keep you imformed
trannytech wrote:only the front wheel drive modeels have ps pump water pump arrangement have only changed one since they came out and i work in a ford dealer have the same setup on the mondeo and naever had one go on those either
Users browsing this forum: Google [Bot], gsc1ugs
